Oracle monitoring
  • stefano
    • Sep 2007
    • 12
    #31
    checking alert.log
    This addon is very usefull. But I think must also be monitored the alert.log file for any ORA- error.
    Stefano
    • vikty
      • Jul 2007
      • 104
      #32
      I have installed the oracle client.
      How it works well
      PS
      Is there a version most recent??
      • jonnjonzzn
        • Sep 2007
        • 18
        #33
        Thyank You
        Another note of thank you. If I can figure out how to use the wiki I'm going to consolidate the information from this thread there with download links, etc. Basically, a zabora howto. Nobody has done this yet, correct?
        • vikty
          • Jul 2007
          • 104
          #34
          Script Tunning
          do anyone know a web site (or anything) with a list of SQL query, to insert into zabora script?
          I have written these simple queries:
          'procnum')
                  sql="select to_char(count(1)) from v\$process;" #process number
          'sessnum')
                  sql="select to_char(count(1)) from v\$session;" #session number
          I like this tipe of monitoring, because is very customiseable
          • skanx
            • Oct 2007
            License ?
            first of all, thank you for sharing this very useful script !
            I don't see any license information in the files. Do you plan to release it in a free license like the GPL ?
            In the meantime, is it possible for me to redistribute it ?
            I am writing an open source documentation about Oracle monitoring with Zabbix using snmp, but some of the values I want aren't available via snmp. I use Zabora to get these values, and since Zabora is only available on this forum, it would be easier for the reader if I could disribute Zabora alongside my doc and scripts, in a single package.
            This documentation/howto should be available soon on this forum.
            Thanks in advance,
            Nicolas.
            • den_crane
              • Feb 2006
              • 272
              #36
              Originally posted by skanx
              Hi,first of all, thank you for sharing this very useful script !
              Thank you.
              I was lazy to form it.
              zabora is copyleft. You can redistribute it under GPL.
              Sorry for my English.
              • vikty
                • Jul 2007
                • 104
                #37
                Under GPL each modify, must I communicate any changement?? correct??
                • den_crane
                  • Feb 2006
                  • 272
                  #38
                  no. You must give open access for your modification to any who ask.
                  • skanx
                    • Oct 2007
                    Thanks for your answer, den_crane,
                    the documentation and scripts are now available here: http://opensources.octant-fr.com/
                    • max
                      • Jan 2008
                      • 36
                      #40
                      Same problem as Vikty
                      Config :
                      Server > Ubuntu 7.10 - Zabbix 1.4.4
                      Client > Red Hat Enterprise Linux AS release 4 (October Update 4) - Zabbix_Agent 1.4.2
                      Using zabora, I've got the same problem as vikti. I've solved permissions problems by putting the user zabbix in oinstall group. But I have a new problem, see below...
                      Here is the log file I have in the zabbix_agent.log of the monitored client :
                        8978:20080109:061331 zabbix_agentd started. ZABBIX 1.4.2.
                        8980:20080109:061331 zabbix_agentd collector started
                        8981:20080109:061331 zabbix_agentd listener started
                        8982:20080109:061331 zabbix_agentd listener started
                        8984:20080109:061331 zabbix_agentd listener started
                        8985:20080109:061331 zabbix_agentd active check started [10.68.89.109:10051]
                      + zaboraver=1.5
                      + rval=0
                      + case $1 in
                      + sql='select to_char(count(*)-1, '\''FM99999999999999990'\'') retvalue from v$session where username is not null;'
                      + '[' 'select to_char(count(*)-1, '\''FM99999999999999990'\'') retvalue from v$session where username is not null;' '!=' '' ']'
                      + echo 'select to_char(count(*)-1, '\''FM99999999999999990'\'') retvalue from v$session where username is not null;'
                      + /u02/oracle/product/10.2.0/bin/sqlplus -s /nolog @/u02/agent/zabora/cont.sql
                      [B]/u02/oracle/product/10.2.0/bin/sqlplus: error while loading shared libraries: libsqlplus.so: cannot open shared object file: No such file or directory[/B]
                      + rval=127
                      + '[' 127 -ne 0 ']'
                      + echo ZBX_NOTSUPPORTED
                      + exit 127
                      Is anyone experiencing some problem using sqlplus within zabbix agent ?
                      Does anyone have a solution before I try installing the oracle client as vikty did ?
                      • valerio.crini
                        #41
                        I had similar problems when my oracle variables were wrong.
                        Try to modify oraenv (part of zabora package) and your zabbix user's .bashrc.
                        • max
                          • Jan 2008
                          • 36
                          #42
                          Thanks for your answer valerio.crini
                          Something I forgot to said is that zabora works perfectly in the shell with the zabbix user...
                          Anyway, I've added ORACLE_HOME and LD_LIBRARY_PATH in .bash_profile.
                          Here is my oraenv :
                          export ORACLE_HOME=/u02/oracle/product/10.2.0
                          export ORACLE_SID=BUL
                          export PATH=$PATH:/usr/bin:/usr/sbin/:/u02/oracle/product/10.2.0/bin
                          export LD_LIBRARY_PATH=$ORACLE_HOME/lib
                          #export NLS_LANG=american_cis.cl8mswin1251
                          Note : Is NLS_LANG useful for the good working of the script ?
                          But I have the same error after restarting my agent...
                          • valerio.crini
                            #43
                            hints
                            Have zabora run successful as bash script or from zabbix_agent with -t option? When I have a problem first I use /usr/local/sbin/zabbix_agentd -t oracle[usercount] and if it fails as /usr/local/sbin/zabora usercount.
                            If from shell run successfully I ask you to compare your linux user with the user that is running your zabbix_agentd (you can see with top).
                            I had problem at running zabbix_agentd as root so I changed starting script in /etc/init.d to change user in 'zabbix'
                            su - zabbix -c /usr/local/sbin/zabbix_agentd
                            and it worked.
                            In my bash profile I added oracle environment in order to test queries without changing user when i had to start mysql.
                            Here is my oraenv :
                            I am not a oracle Guru but in first post of this thread I found it so i adopted it ....
                            • max
                              • Jan 2008
                              • 36
                              #44
                              Some news...
                              It works !... but I'm not sure the reason why...
                              In fact, on the monitored server, the inclusion of the oraenv file didn't worked so I put the content of oraenv directly in the zabora script... and it worked. Weird.
                              Another thing I found weird : I've performed some tests with the zabbiix user on my zabbix server and on the monitored server... The script itself works but through zabbix_agentd, it doesn't...however the result are correctly sent to the server because the graphs are working ! See below :
                              (Ubuntu 7 : ZABBIX Server + Oracle XE)
                              zabbix@test-desktop:~$ /home/zabbix/zabora-1.2/zabora rcachehit
                              95.1736
                              zabbix@test-desktop:~$ /usr/sbin/zabbix_agentd -t oracle[rcachehit]
                              oracle[/home/zabbix/zabora-1.2/zabora zaboraver ]  [t| 95.1736]
                              (Redhat 4 : Oracle 10g)
                              [zabbix@dbavm ~]$ /u02/agent/zabora/zabora rcachehit
                              99.7996
                              [zabbix@dbavm ~]$ /usr/sbin/zabbix_agentd -t oracle[rcachehit]
                              oracle                                        [m|ZBX_NOTSUPPORTED]
                              Could someone explain this ?
                              • bee
                                • Jun 2007
                                • 133
                                #45
                                ZABORA and multiple OID value calculation
                                Hi All,
                                First of all, sorry if this quite silly question for someone out there but i insist to post it
                                I'm new comer of Oracle, and have oppurtunity to try it on one of my development machine with Windows 2003 Server platform.
                                My question, how do i use ZABORA on windows 2003?
                                Ussualy, i'm quite famililar with retrieving snmp value on zabbix to monitor most of network devices such as server, router etc.
                                But how do i retrieve "correct" Oracle snmp value for example Cache Hit Ratio.
                                In oracle documentation they publish as follow
                                Cache Hit Ratio - This ratio measures the effectiveness of the buffer cache. The normally acceptable range is 70 - 85%.
                                (oraDbSysConsistentGets + oraDbSysBlockGets - oraDbSysPhysReads) /
                                (oraDbSysConsistentGets + oraDbSysBlockGets)
                                In my understanding on what Oracle documentation said, we need to do simple arithmatic calculation on several Oracle OID to get Cache Hit ratio. am i right?
                                If yes, how do i perform it on zabbix?as my understanding, zabbix cannot do multiple OID arithmatic calculation.
                                Thanks,
                                BEE
