Zabbix 1.3.2 Apache Template and Script
  • clahti
    • Jan 2007
    • 126
    Hello all:
    Here is the first of what I hope to be many scripts that improve and extend the functionality of the Zabbix system, this one is a rather trivial example but I find it useful and hopefully someone else will as well. Here are instructions for installation and useage:
    # apachestats Zabbix UserAgent Script
    # 20070206 [email protected] original version this has only been tested on Zabbix 1.3.2
    # INSTALLATION AND USAGE:
    # (1) This requires mod_status apache module to be installed and configured for access by 127.0.0.1
    # in httpd.conf something like:
    # LoadModule status_module modules/mod_status.so
    # ExtendedStatus On
    # <Location /server-status>
    # SetHandler server-status
    # Order deny,allow
    # Deny from all
    # Allow from 127.0.0.1
    # </Location>
    # (2) Place this script in your Zabbix Scripts path, on RH usually /usr/lib/zabbix/
    # (3) Place the following UserParameters in your zabbix_agent.conf or zabbix_agentd.conf
    # make sure you change the path if necessary
    # UserParameter=apache.ttl_accesses,/usr/lib/zabbix/zabbix_apachestats.pl -p ttl_accesses
    # UserParameter=apache.ttl_traffic,/usr/lib/zabbix/zabbix_apachestats.pl -p ttl_traffic
    # UserParameter=apache.cpu_load,/usr/lib/zabbix/zabbix_apachestats.pl -p cpu_load
    # UserParameter=apache.uptime,/usr/lib/zabbix/zabbix_apachestats.pl -p uptime
    # UserParameter=apache.req_sec,/usr/lib/zabbix/zabbix_apachestats.pl -p req_sec
    # UserParameter=apache.bytes_sec,/usr/lib/zabbix/zabbix_apachestats.pl -p bytes_sec
    # UserParameter=apache.bytes_req,/usr/lib/zabbix/zabbix_apachestats.pl -p bytes_req
    # UserParameter=apache.busy_workers,/usr/lib/zabbix/zabbix_apachestats.pl -p busy_workers
    # UserParameter=apache.idle_workers,/usr/lib/zabbix/zabbix_apachestats.pl -p idle_workers
    # (4) Import the templates into your zabbix server
    # (5) for each host, add the template that have apache running
    Let me know if you find it useful or find any problems!
    /Chris
  • Blackerado
    • Jun 2013
    I was giving this a shot and it seems to have loaded correctly... im seeing some errors though in the zabbix console saying that the items are not supported. Do you know what im missing? I tried running the commands manually and they give no output.
    Thanks,
