OK, I am actually getting information off of our Cisco load balancer. I am not an SNMP expert nor a Cisco expert so please jump in and add clarification to this thread if able. It seems as if I was never giving Zabbix the correct OID or key for the items I wanted to retrieve.
Here are links to similar discussions here in the forums:
I figured it out by a process similar to below:
First, download the MIBs from Cisco and place them whevever the rest of your MIBs are located. On Red Hat/CentOS that is: /usr/share/snmp/mibs
I am going to give an example for an item we are capturing which gives the number of TCP Connections to one of the clustered application servers behind it.
We grab this value for each of the app servers to verify our load is being properly balanced among the app cluster members. If you don't know what you're looking for start small like "conn" hoping to get back some connection related parameters and drill down from there. Eventually I find out I want this:
OK, we have all we need.
The OID for this item is:
.1.3.6.1.4.1.9.9.470.1.1.3.1.14.12.10.66.76.65.67. 75.66.79.65.82.68.4.68.85.83.84.0
and the key is:
enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.7 5.66.79.65.82.68.4.68.85.83.84.0
Here is the associated zabbix item configuration:
Repeat this procedure for other items. To get a list of generic SNMP items do this:
and then repeat process above.
Example:
Now, we're ready to create item.
OID: .1.3.6.1.2.1.2.2.1.10.16777231
key: ifInOctets.16777231
-Mike
[root]# cd /usr/share/snmp/mibs
[root@wraith mibs]# grep -i 'currentconn' CISCO* CISCO-ENHANCED-SLB-MIB.my: cesServerFarmRserverCurrentConns Counter64, CISCO-ENHANCED-SLB-MIB.my:cesServerFarmRserverCurrentConns OBJECT-TYPE CISCO-ENHANCED-SLB-MIB.my: cesServerFarmRserverCurrentConns, CISCO-SLB-EXT-MIB.my: cslbxRuleCurrentConnections Gauge32, CISCO-SLB-EXT-MIB.my:cslbxRuleCurrentConnections OBJECT-TYPE CISCO-SLB-EXT-MIB.my: cslbxRuleCurrentConnections,
[root@wraith mibs]# snmptranslate -m ALL -On -IR cesServerFarmRserverCurrentConns 2>/dev/null .1.3.6.1.4.1.9.9.470.1.1.3.1.14
[root@wraith mibs]# snmpwalk 192.168.1.5 -c public -v 2c .1.3.6.1.4.1.9.9.470.1.1.3.1.14 2> /dev/null SNMPv2-SMI::enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.4.68.85.83.84.0 = Counter64: 21 SNMPv2-SMI::enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.5.67.72.65.76.75.0 = Counter64: 23 SNMPv2-SMI::enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.6.83.84.89.76.85.83.0 = Counter64: 47
[root@wraith mibs]# snmptranslate -m ALL -On -IR SNMPv2-SMI::enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.4.68.85.83.84.0 2>/dev/null .1.3.6.1.4.1.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.4.68.85.83.84.0
and the key is:
<item type="4" key="enterprises.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.4.68.85.83.84.0" value_type="3"> <description>Load Balancer Active TCP Connections - Dust</description> <delay>30</delay> <history>90</history> <trends>365</trends> <formula>1</formula> <snmp_community>public</snmp_community> <snmp_oid>.1.3.6.1.4.1.9.9.470.1.1.3.1.14.12.10.66.76.65.67.75.66.79.65.82.68.4.68.85.83.84.0</snmp_oid> <snmp_port>161</snmp_port> </item>
[root]# snmpwalk 192.168.1.5 -c public -v 2c 2> /dev/null
Example:
[root@wraith mibs]# snmpwalk 192.168.1.5 -c public -v 2c 2> /dev/null | grep -i octets IF-MIB::ifInOctets.16777231 = Counter32: 2861642552 IF-MIB::ifInOctets.16777753 = Counter32: 1203117344 IF-MIB::ifInOctets.33554447 = Counter32: 0 IF-MIB::ifOutOctets.16777231 = Counter32: 388385046 IF-MIB::ifOutOctets.16777753 = Counter32: 2551396700 IF-MIB::ifOutOctets.33554447 = Counter32: 0 IP-MIB::ipSystemStatsInOctets.ipv4 = Counter32: 2586604045 IP-MIB::ipSystemStatsHCInOctets.ipv4 = Counter64: 3352661094925 IP-MIB::ipSystemStatsOutOctets.ipv4 = Counter32: 2194988618 IP-MIB::ipSystemStatsHCOutOctets.ipv4 = Counter64: 6489955914 IP-MIB::ipIfStatsInOctets.ipv4.16777231 = Counter32: 1650052595 IP-MIB::ipIfStatsInOctets.ipv4.16777753 = Counter32: 936551450 IP-MIB::ipIfStatsInOctets.ipv4.33554447 = Counter32: 0 IP-MIB::ipIfStatsHCInOctets.ipv4.16777231 = Counter64: 1221420764659 IP-MIB::ipIfStatsHCInOctets.ipv4.16777753 = Counter64: 2131240330266 IP-MIB::ipIfStatsHCInOctets.ipv4.33554447 = Counter64: 0 IP-MIB::ipIfStatsOutOctets.ipv4.16777231 = Counter32: 330506628 IP-MIB::ipIfStatsOutOctets.ipv4.16777753 = Counter32: 1864481990 IP-MIB::ipIfStatsOutOctets.ipv4.33554447 = Counter32: 0 IP-MIB::ipIfStatsHCOutOctets.ipv4.16777231 = Counter64: 4625473924 IP-MIB::ipIfStatsHCOutOctets.ipv4.16777753 = Counter64: 1864481990 IP-MIB::ipIfStatsHCOutOctets.ipv4.33554447 = Counter64: 0 IF-MIB::ifHCInOctets.16777231 = Counter64: 1222632354616 IF-MIB::ifHCInOctets.16777753 = Counter64: 2131506896160 IF-MIB::ifHCInOctets.33554447 = Counter64: 0 IF-MIB::ifHCOutOctets.16777231 = Counter64: 4683352342 IF-MIB::ifHCOutOctets.16777753 = Counter64: 2551396700 IF-MIB::ifHCOutOctets.33554447 = Counter64: 0
[root@wraith mibs]# snmptranslate -m ALL -On -IR IF-MIB::ifInOctets.16777231 2>/dev/null .1.3.6.1.2.1.2.2.1.10.16777231
-Mike
