Use my script to get SignalStrength from D-link DWL-3200 or 2100
  • fableman
    • Oct 2007
    • 78
    DWL-SignalStrength is a linux script that you can use to get Rx or Ack Signal Strength from D-link Wireless Units DWL-3200 or DWL-2100
    USAGE: DWL-SignalStrength x.x.x.x Rx/Ack password MAC
    (ex. ./DWL-SignalStrength 10.123.123.2 Rx password or ./DWL-SignalStrength 10.123.123.2 Ack password 00:13:86:22:a2:1c)
    x.x.x.x = IP-address or Host name
    Rx = RxSignalStrength Ack = AckSignalStrength
    password = admin password for telnet login
    MAC = Mac address. Only needed if you have more then one Radio device configured. (ex. 00:13:86:22:a2:1c)
    Version: 1.0 (2007-12-06)
    Includes: DWL-grep DWL-SignalStrength
    unpack: tar -zxvf DWL-SignalStrength.tgz
    configure: vim DWL-SignalStrength
    edit the line: dwlgrep="/etc/zabbix/externalscripts" #The script dwl-grep must be at that location you put in there.
    DOWNLOAD FROM http://software.mediakonst.se/
    HOW TO USE WITH Zabbix:
    1. download DWL-SignalStrength.tgz to /etc/zabbix/externalscripts
    2. tar -zxvf DWL-SignalStrength.tgz
    3 make Host
    MUST BE NAMED WITH ONLY IP ADDRESS OR VALID DNS NAME
    (until zabbix get out with a version that will only send ip or dns address to external scripts and not host name as now )
    4. make Item as ex.
    Description: SinglaStrength Rx
    Type: External check
    Key: DWL-SignalStrength[ Rx youradminpassword]
    Type of Information: Numric (integer 64bit)
    Units: % Rx
    Use multiplier: Do not use
    (repalce all Rx with Ack if you want that signal instead)
    5 trigger
    if signal is lower then 6 % maybee ya need to check if a tree grew up infront of the antenna or soo
    Hope you like this cos I got it running and monitoring 16 units DWL-3200 and can easy see how the signal strength in % changes and if I need to replace antennas or cut down some trees
    Any problems let me know.
