monitor virtuozzo privvmpages (and others)
  • globifrosch
    • Sep 2005
    • 74
    i have some Virtuozzo hosts. There is one parameter (at least for me) to watch out for: privvmpages
    so now, this is how you can do it:
    1. save this script somewhre (eg. /usr/local/bin)
    PHP Code:
    #!/bin/sh
    if [ -z $1 ] ; then echo argument error && exit 1; fi;
    COLUMN=1
    case $2 in
      held
    )    COLUMN=1 ;;
    maxheld) COLUMN=2 ;;
    barrier) COLUMN=3 ;;
    limit)   COLUMN=4 ;;
    failcnt) COLUMN=5 ;;
    esac
    REGEX
    ='s| +[a-z]+ +([0-9]+) +([0-9]+) +([0-9]+) +([0-9]+) +([0-9]+)|'
    REGEX="$REGEX\\${COLUMN}|"
    cat /proc/user_beancounters | grep $1 | sed -r "$REGEX"
    2. add a UserParameter to zabbix_agendtd.conf (or whatever zabbix*.conf you are using:
    PHP Code:
    UserParameter=vz[*],sudo <pathtoyoursavedscript> $1 $2
    3. edit the sudoers file (aka: visudo)
    PHP Code:
    zabbix  ALL=(root) NOPASSWD: <pathtoyoursavedscript>
    4. restart zabbix_agent
    5. add new item with key "vz[privvmpages,held]", "vz[privvmpages,barrier]", vz[privvmpages,failcnt], etc. Have a look at /proc/user_beancounters what other counters and limits there are.
