I've created a link between a host and a template. For graphs this seems to result in the adding/deleting of graphs elements of the host when I add graph elements of the template to a graph.
But this seems to fail: if I create a graph called "test" and add an item from the template to it, I get 2 errors:
Error in query [select hostid,host,useip,ip,port_status from hosts where hostid=]
==> this error seems to be related to the select statement on line 137 in graph.inc.php (version 1.1alpha10): the hostid is empty because there's is no such graph related to the host.
Second error:
ERROR EXECUTING: insert into graphs (name,width,height,yaxistype,yaxismin,yaxismax) values ('test',900,200,0,0,0000,100.0000)
==> this error is related to line 142 of the same file: since the first query failed, a new graph is being added, but with the same name as the old graph! This of course fails ...
I tried naming my graph "cpu {hostname}" but this fails also ...
So any help or a quick howto is very much appreciated.
Franky
Second error:
Franky
