Zabbix 1.5.4 - Build 5868 - Frontend - Configuration -> Host
  • Palmertree
    • Sep 2005
    • 746
    When viewing hosts under configuration, and if a user selects "Group = all" nothing is displayed on the screen.
    Invalid URL: https://server.domain.com/zabbix/hos...ig=0&groupid=0
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Same here, can't reproduce this. Could be a DM related problem.. When I'll have an installed DM, I'll test it.
    Zabbix | ex GUI developer
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      Palmertree, have you checked httpd error log file? The problem might by in lack of memory for php..
      • Palmertree
        • Sep 2005
        • 746
        Thanks I will give that a try. When I cleared the session table it seemed to fix the problem for some reason. If it comes back I will check php memory. Thanks for the pointer.
