1.5.4 system.cpu.util on linux agent crashes
  • robertmcox
    • Jul 2008
    So I upgraded to 1.5.4 (from 1.5.3) today and found a couple issues that were already resolved by others on the forum (thank you guys!). But I did find another issue:
    After upgrading the linux agent to 1.5.4 (on CentOS 5.1), the agent will crash if I have an item for 'system.cpu.util[,idle,avg1]'. It does not matter whether the check is active or passive. I also verified that agent 1.5.3 does NOT have this problem, and downgrading is my current workaround for the issue.
    /tmp/zabbix_agent.log:
      8172:20080824:183418 In send_buffer('127.0.0.1','10051')
      8172:20080824:183418 Values in the buffer 6 Max 100
      8172:20080824:183418 Will not send now. Now 1219602858 lastsent 1219602854 < 5
      8172:20080824:183418 Sleeping for 1 seconds
      8169:20080824:183419 Processing request.
      8169:20080824:183419 In check_security()
      8169:20080824:183419 Requested [system.cpu.util[all,idle,avg1]]
      8167:20080824:183419 One child process died. Exiting ...
      8167:20080824:183419 zbx_on_exit() called.
      8172:20080824:183419 Got signal. Exiting ...
      8170:20080824:183419 Got signal. Exiting ...
      8171:20080824:183419 Got signal. Exiting ...
      8168:20080824:183419 Got signal. Exiting ...
      8167:20080824:183421 ZABBIX Agent stopped. ZABBIX 1.5.4.
    I compiled using:
    make clean
    ./configure --enable-agent --prefix=/opt/zabbix --enable-static
    make install
    The In check_security() concerns me. Although I have not changed any permissions nor performed any package updates before or after upgrading, I have hardened the system(s) by changing permissions on certain system binaries and paths from the defaults. My zabbix_agentd runs as the user 'zabbix'.
    If noone else has this same issue with the new agent, could someone enlighten me as to what "security checks" are new in 1.5.4?
  • AlienBrew
    • Mar 2008
    I got the same issue on a fedora system.
    The solution was as above to downgrade the agent.
    • disgruntleddutch
      • Oct 2006
      • 34
      Having the same problem with 1.5.4
       19978:20080909:231238 Processing request.
       19978:20080909:231238 In check_security()
       19978:20080909:231238 Requested [vfs.fs.size[/,used]]
       19978:20080909:231238 Sending back [15539576]
       19979:20080909:231238 Processing request.
       19979:20080909:231238 In check_security()
       19979:20080909:231238 Requested [vfs.fs.size[/,free]]
       19979:20080909:231238 Sending back [227427252]
       19980:20080909:231238 Processing request.
       19980:20080909:231238 In check_security()
       19980:20080909:231238 Requested [vfs.fs.inode[/usr,free]]
       19980:20080909:231238 Sending back [62613896]
       19978:20080909:231238 Requested [vfs.fs.inode[/opt,pfree]]
       19978:20080909:231238 Sending back [99.834089]
       19979:20080909:231238 Requested [vfs.fs.size[/,pfree]]
       19979:20080909:231238 Sending back [93.604240]
       19980:20080909:231238 Requested [vfs.fs.size[/tmp,free]]
       19980:20080909:231238 Sending back [227427252]
       19978:20080909:231238 Requested [vm.memory.size[free]]
       19978:20080909:231238 Sending back [9046278144]
       19979:20080909:231238 Requested [vfs.fs.size[/opt,used]]
       19980:20080909:231238 Requested [vfs.fs.size[/home,free]]
       19979:20080909:231238 Sending back [15539576]
       19978:20080909:231238 Requested [vfs.fs.size[/home,pfree]]
       19978:20080909:231238 Sending back [93.604238]
       19979:20080909:231238 Requested [net.tcp.service[pop]]
       19979:20080909:231238 TCP expect error: Cannot connect to [127.0.0.1:110] [Connection refused]
       19979:20080909:231238 Sending back [0]
       19979:20080909:231238 Requested [vfs.fs.size[/var,free]]
       19979:20080909:231238 Sending back [30602136]
       19978:20080909:231238 Requested [vm.memory.size[shared]]
       19978:20080909:231238 Sending back [0]
       19979:20080909:231238 Requested [vfs.fs.size[/usr,free]]
       19978:20080909:231238 Requested [net.if.out[lo,bytes]]
       19978:20080909:231238 Sending back [2499423]
       19980:20080909:231238 Requested [vfs.fs.size[/usr,used]]
       19980:20080909:231238 Sending back [15539576]
       19979:20080909:231238 Requested [vm.memory.size[buffers]]
       19979:20080909:231238 Sending back [235102208]
       19978:20080909:231238 Requested [net.if.in[eth1,bytes]]
       19980:20080909:231238 Requested [vfs.fs.size[/opt,pused]]
       19980:20080909:231238 Sending back [6.395760]
       19979:20080909:231238 Requested [net.if.in[lo,bytes]]
       19979:20080909:231238 Sending back [2502522]
       19978:20080909:231238 Requested [vfs.fs.size[/usr,pfree]]
       19978:20080909:231238 Sending back [93.604240]
       19980:20080909:231238 Requested [vfs.fs.size[/tmp,used]]
       19979:20080909:231238 Requested [net.if.in[eth0,bytes]]
       19979:20080909:231238 Sending back [2239753339]
       19980:20080909:231238 Sending back [15539580]
       19978:20080909:231239 Processing request.
       19978:20080909:231239 In check_security()
       19978:20080909:231239 Requested [vfs.fs.size[/tmp,pfree]]
       19978:20080909:231239 Sending back [93.604238]
       19979:20080909:231239 Processing request.
       19979:20080909:231239 In check_security()
       19979:20080909:231239 Requested [vfs.fs.size[/tmp,pused]]
       19979:20080909:231239 Sending back [6.395760]
       19980:20080909:231239 Processing request.
       19980:20080909:231239 In check_security()
       19980:20080909:231239 Requested [vfs.fs.size[/var,pused]]
       19978:20080909:231239 Requested [vfs.fs.size[/home,used]]
       19980:20080909:231239 Sending back [5.842445]
       19978:20080909:231239 Sending back [15539576]
       19979:20080909:231239 Requested [vfs.fs.size[/usr,pused]]
       19979:20080909:231239 Sending back [6.395765]
       19980:20080909:231239 Requested [vfs.fs.size[/,pused]]
       19980:20080909:231239 Sending back [6.395760]
       19978:20080909:231239 Requested [vfs.fs.size[/var,pfree]]
       19978:20080909:231239 Sending back [94.157555]
       19979:20080909:231239 Requested [vfs.fs.size[/opt,pfree]]
       19979:20080909:231239 Sending back [93.604240]
       19979:20080909:231239 Requested [vfs.fs.size[/opt,free]]
       19979:20080909:231239 Sending back [227427252]
       19980:20080909:231239 Requested [vm.memory.size[cached]]
       19980:20080909:231239 Sending back [21334712320]
       19979:20080909:231239 Requested [proc.num[,,run]]
       19978:20080909:231239 Requested [net.tcp.service[imap]]
       19978:20080909:231239 TCP expect error: Cannot connect to [127.0.0.1:143] [Connection refused]
       19978:20080909:231239 Sending back [0]
       19980:20080909:231239 Requested [vfs.fs.size[/var,used]]
       19980:20080909:231239 Sending back [1898852]
       19978:20080909:231239 Requested [proc.num[sshd]]
       19980:20080909:231239 Requested [net.tcp.service[http]]
       19980:20080909:231239 Sending back [1]
       19979:20080909:231239 Sending back [4]
       19978:20080909:231239 Sending back [1]
       19980:20080909:231239 Requested [vfs.fs.inode[/usr,pfree]]
       19980:20080909:231239 Sending back [99.834089]
       19979:20080909:231239 Requested [vfs.fs.inode[/home,pfree]]
       19979:20080909:231239 Sending back [99.834089]
       19978:20080909:231239 Requested [net.tcp.service[nntp]]
       19978:20080909:231239 TCP expect error: Cannot connect to [127.0.0.1:119] [Connection refused]
       19980:20080909:231239 Requested [net.tcp.service[ssh]]
       19979:20080909:231239 Requested [proc.num[inetd]]
       19979:20080909:231239 Sending back [0]
       19978:20080909:231239 Requested [proc.num[zabbix_server]]
       19978:20080909:231239 Sending back [302]
       19980:20080909:231239 Requested [system.cpu.util[,user,avg1]]
       19975:20080909:231239 One child process died. Exiting ...
       19979:20080909:231239 Got signal. Exiting ...
       19977:20080909:231239 Got signal. Exiting ...
       19978:20080909:231239 Got signal. Exiting ...
       19975:20080909:231239 zbx_on_exit() called.
       19981:20080909:231239 Got signal. Exiting ...
       19975:20080909:231241 ZABBIX Agent stopped. ZABBIX 1.5.4.
      • disgruntleddutch
        • Oct 2006
        • 34
        I should note that this is only happening on RHEL5 based systems, not RHEL4 (at least so far).
        • Daniel Carnevalli
          • Nov 2008
          • 14
          I have the same problem with Fedora 9 and RedHat 5.1
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            What? 1.5.x? These are beta releases!
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
