Hi. I am using Zabbix 1.5.4 (02.09.08 nightly build).
I have a IP-relative host with item: IF-MIB::ifOperStatus.5 (SNMPv2 agent).
But it has SNMP error [1] error.
I can do
Using tcpdump I can see the following:
In zabbix_server.log:
But this item (in the 172.20.1.103 and other hosts) has "Not supported" status with "SNMP error [1]" error.
It's strange, because few days ago (4-5) it worked fine! I think it started when I upgraded to some next nightly build (~27-28.08.08).
Furthermore, some SNMP items still works from Zabbix (DOCS-IF-MIB::docsIfCmStatusValue.2, SNMPv2 agent - Active).
But some (IF-MIB::ifOperStatus etc) stoped working on all of ~500 hosts.
What can be wrong?
Thank you!
Zabbix 1.5.4b (02.09.08)
FreeBSD 7.0
net-snmp: 5.4.1.2
I can do
%snmpwalk -c CORRECTCOMMUNITY -v 2c 172.20.1.103 IF-MIB::ifOperStatus.5
IF-MIB::ifOperStatus.5 = INTEGER: down(2)
15:56:00.212778 IP 10.50.0.9.55151 > 172.20.1.103.snmp: C=CORRECTCOMMUNITY GetRequest(30) interfaces.ifTable.ifEntry.ifOperStatus.5
15:56:00.221921 IP 172.20.1.103.snmp > 10.50.0.9.55151: C=CORRECTCOMMUNITY GetResponse(31) interfaces.ifTable.ifEntry.ifOperStatus.5=2
4355:20080902:161358 SNMP [[email protected]:161:161]
4355:20080902:161358 OID [IF-MIB::ifOperStatus.5]
4355:20080902:161358 In get_value_SNMP() 0.2
4355:20080902:161358 In get_value_SNMP() 0.3
4355:20080902:161359 Status send [0]
4355:20080902:161359 In get_value_SNMP() 0.4
4355:20080902:161359 In get_value_SNMP() 1
4355:20080902:161359 In get_value_SNMP() 2
4355:20080902:161359 AV loop(2)
4355:20080902:161359 End get_value()
4355:20080902:161359 In process_new_value(IF-MIB::ifOperStatus.5)
4355:20080902:161359 In dc_add_history(itemid:20398,key:"IF-MIB::ifOperStatus.5",value_type:3,UINT64:2)
4355:20080902:161359 End of add_history
4355:20080902:161359 In DCadd_nextcheck()
4355:20080902:161359 In calculate_item_nextcheck (20398,60,,1220361239)
4355:20080902:161359 End calculate_item_nextcheck (result:1220361298)
4355:20080902:161359 In int_in_list(list:,value:10106)
4355:20080902:161359 End int_in_list(ret:FAIL)
4355:20080902:161359 In get_value(key:IF-MIB::ifOperStatus.1)
4355:20080902:161359 In get_value_snmp(key:IF-MIB::ifOperStatus.1, oid:IF-MIB::ifOperStatus.1)
4355:20080902:161359 Standard processing
4355:20080902:161359 In snmp_normalize(oid:IF-MIB::ifOperStatus.1)
4355:20080902:161359 End of snmp_normalize(result:IF-MIB::ifOperStatus.1)
4355:20080902:161359 In get_snmp(oid:IF-MIB::ifOperStatus.1)
What can be wrong?
Thank you!
FreeBSD 7.0
net-snmp: 5.4.1.2
