Hi folks,
I generated this for 1.5.4 (from 1.5.3). Enjoy!
SET FOREIGN_KEY_CHECKS = 0;
# DDL START
ALTER TABLE escalations
ADD r_eventid bigint(20) unsigned NOT NULL DEFAULT '0' COMMENT '' AFTER eventid,
COMMENT='InnoDB free: 11264 kB';
ALTER TABLE events
DROP INDEX events_3;
ALTER TABLE httpstep
MODIFY url varchar(255) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci;
# Fieldformat of
# httpstep.url changed from varchar(128) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci to varchar(255) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci.
# Possibly data modifications needed!
ALTER TABLE opconditions
ALTER TABLE profiles
ADD idx2 bigint(20) unsigned NOT NULL DEFAULT '0' COMMENT '' AFTER idx,
ADD value_id bigint(20) unsigned NOT NULL DEFAULT '0' COMMENT '' AFTER idx2,
ADD value_int int(11) NOT NULL DEFAULT '0' COMMENT '' AFTER value_id,
ADD value_str varchar(255) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci AFTER value_int,
ADD type int(11) NOT NULL DEFAULT '0' COMMENT '' AFTER source,
MODIFY idx varchar(96) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci,
[URL="http://74.223.101.213/mysqldiff/index.php?sc=field&table=profiles&field=value&fields%5B%5D=idx2&fields%5B%5D=value_id&fields%5B%5D=value_int&fields%5B%5D=value_str&fields%5B%5D=type"]DROP[/URL] value,
[URL="http://74.223.101.213/mysqldiff/index.php?sc=field&table=profiles&field=value2&fields%5B%5D=idx2&fields%5B%5D=value_id&fields%5B%5D=value_int&fields%5B%5D=value_str&fields%5B%5D=type"]DROP[/URL] value2,
MODIFY source varchar(96) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci,
[URL="http://74.223.101.213/mysqldiff/index.php?sc=field&table=profiles&field=valuetype&fields%5B%5D=idx2&fields%5B%5D=value_id&fields%5B%5D=value_int&fields%5B%5D=value_str&fields%5B%5D=type"]DROP[/URL] valuetype,
DROP INDEX profiles_1,
ADD INDEX profiles_1 (userid, idx, idx2);
# Fieldformats of
# profiles.idx changed from varchar(64) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci to varchar(96) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci.
# profiles.source changed from varchar(255) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci to varchar(96) NOT NULL DEFAULT '' COMMENT '' COLLATE latin1_swedish_ci.
ALTER TABLE proxy_history
ADD itemid bigint(20) unsigned NOT NULL DEFAULT '0' COMMENT '' AFTER id,
[URL="http://74.223.101.213/mysqldiff/index.php?sc=field&table=proxy_history&field=host&fields%5B%5D=itemid"]DROP[/URL] host,
[URL="http://74.223.101.213/mysqldiff/index.php?sc=field&table=proxy_history&field=key_&fields%5B%5D=itemid"]DROP[/URL] key_;
ALTER TABLE rights
DROP type;
ALTER TABLE scripts
ALTER TABLE sessions
ADD status int(11) NOT NULL DEFAULT '0' COMMENT '' AFTER lastaccess;
ALTER TABLE sysmaps_elements
ADD iconid_disabled bigint(20) unsigned NOT NULL DEFAULT '0' COMMENT '' AFTER url;
ALTER TABLE sysmaps_link_triggers
ALTER TABLE trends_uint
# DDL END
SET FOREIGN_KEY_CHECKS = 1;
