Zabbix 1.70 Build 6172 - Host Maintenance - One time only
  • Palmertree
    • Sep 2005
    • 746
    When trying to create a "New maintenance period" the following error is display in the message window "Incorrect maintenance period" when trying to create a Period type "One time only".
    Period type: One time only
    Date: 15/10/2008 01:00
    Maintenance period length 0 Days 1 Hours
    The date is in the Active range. Daily worked without a problem.
    Please let me know if you need additional information.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    My only guess for now is that you tried to save it in IE6, but because IE6 as I understand have problems with js calendar it may influence in overal, I could say more precise if I would had done better error reporting, hadn't time for this. I will do more checks..
    Zabbix | ex GUI developer
    • Palmertree
      • Sep 2005
      • 746
      Aly, you were right. As soon as I got the calendar fixed from the previous post this error went away. Again thanks for the help. Keep up the good work as always.
