Just and idea or a suggestion but if you work in a distributed environment and have groups that are the same name on both the master and child nodes, the same group appears twice on the group drop down for "Copy Selected To...."
Maybe the DM name should appear before the group name like on the dashboard blocks.
For example:
If you have a group named Servers on the Master node and another group name servers on the child node and if you go to "Copy selected to..." and select the group you will see:
Servers
Servers
Maybe something like this would make it easier to distinguish which group goes to which DM:
[Master DM Name] Servers
[Child DM Name] servers
Just a thought. :-) Hate to be picky for a product that is rock solid and great though.
For example:
Servers
Servers
