Schedule Downtime and SLA Timeframes
  • navtek007
    • May 2005
    • 100
    Hi All,
    I know that this question has been asked quite a few times but i am yet to see a answer.
    I would like to know if scheduled downtime will be introduced and also if SLA calcualtions will be done on specified timeframes
    eg: Web Services 6:30am to 6:30pm.
    I can get around the scheduled downtime with scripts to change the monitored state, however I can't seem to find a way to incorporate timeframes with the SLA side of things. If anyone has any ideas then that would be great. Overall the software is great, looking forward to the next release.
    Thanks in advanced.
  • rdg
    • Jun 2005
    • 20
    Check out http://sourceforge.net/docman/displa...&group_id=4141 to see how OpenNMS handles this.
    /Robert
    • navtek007
      • May 2005
      • 100
      Ok so any suggestions on how it can be encorporated with Zabbix?
      • navtek007
        • May 2005
        • 100
        any other suggestions? Alex will this be a feature available in 1.1 or in the future?
        thanks.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I'd like to see it in 1.1.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • crs9
            • Feb 2006
            • 35
            Alexei,
            Is this feature still in the works for 1.1? I'd like to use it to track SLA numbers JUST during business hours, and I think this would work.
            • mary nancy
              • Jul 2005
              • 125
              Hi all,
              I would like to know how to schedule a maintenance windows. For eg: If I have a maintenance activity scheduled between 5.00am to 5.30pm on a particular host. there should be no alerts generated by that host in that time interval....
              Can somebody guide me on this?
              Nancy
              • devros
                • Sep 2006
                this would also be a big one for me. I am currently looking at SLA reporting solutions, and it seems that Zabbix is almost there. Scheduled Downtime and more configuration of reporting would make it perfect for what I need.
                -ed
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  The feature (scheduled downtimes) is already implemented and will be part of ZABBIX 1.4. It won't be introduced in stable 1.1.x.
                  Alexei Vladishev
                  My Twitter
                  • lreadshaw
                    • Jun 2006
                    • 10
                    navtek007,
                    As a newbie to zabbix, I could use some help with implementing a scheduled downtime workaround for now. Could you give me some insight into how you used scripts to put a scheduled maintenance window in place?
                    Thanks,
                    Lawrence
                    • navtek007
                      • May 2005
                      • 100
                      basically i have done the following
                      1. Create maintenance start sql script which basically disables all triggers for all hosts that are enabled
                      update triggers ,functions, items, hosts set triggers.status = 1
                      where triggers.triggerid = functions.triggerid
                      and items.itemid = functions.itemid
                      and hosts.hostid = items.hostid
                      and hosts.host like '%'
                      and hosts.status=0;
                      2. Create a maintenance stop sql script which turns all triggers back on for all hosts that are enabled.
                      update triggers, functions, items, hosts set triggers.status = 0
                      and hosts.status=0;
                      3. Create a cronjob to run these scripts at your scheduled outage/maintenance window or operation hours.
                      eg:
                      00 05 * * 1-6 /home/zabbix/maint_complete.sh # Turn all triggers on at 5:00am Mon-Sat
                      30 18 * * 1-5 /home/zabbix/maint_start.sh # Turn all triggers off at 6:30pm Mon-Fri
                      There are a couple of holes in my solution as you are unaware of what triggers are executed during the night as they are not turned on. to get around this i basically turn triggers on 1.5 hours before the start of our operation hours just to give me a heads up before i get bombed with calls.
                      For me it is handy to get a acurate availability time for our business and it saves me from doing a whole bunch of calculation on the availability report. It also makes Zabbix SLA calculation correct for our infrastructure sla's.
                      hope this helps.
                      • Alexei
                        Founder, CEO
                        • Sep 2004
                        • 5654
                        Note that SLA downtimes are already implemented in beta code of 1.4 (1.3.x).
                        Alexei Vladishev
                        My Twitter
