Version Pre 1.7.0 Build 6637 - "ERROR: Invalid URL"
  • Palmertree
    • Sep 2005
    • 746
    ERROR: Invalid URL
    If an admin goes to configuration of Items or host and tries to disable or enable the items from the overall screen by clicking the link under the column "Status", they are thrown a "ERROR: Invalid URL".
  • bbrendon
    • Sep 2005
    • 873
    I also noticed in this build that you can't delete a simple graph from a screen. I get a URL error.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      Should be fixed in rev. 6644
      Zabbix | ex GUI developer
      • Palmertree
        • Sep 2005
        • 746
        Aly thanks for the quick fix. Works great. I am not sure if it is my end but it looks like the graph buttons in the top right do not work. For example, the full screen, graph reset, etc.
        • Palmertree
          • Sep 2005
          • 746
          Also if you are in configuration, host, templates and if you click on the "select" button to the right of the template, the pop-up menu does not show up. Maybe it is my end. :-)
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            I will check graph buttons But select in hosts should work
            • richlv
              • Oct 2005
              • 3112
              i can't test it right now, but also initial frontend setup threw invalid url error when trying to progress past first screen.
              • Aly
                ZABBIX developer
                • May 2007
                • 1126
                Already saw that will be fixed.
