Version Pre 1.7.0 Build 6668 -- Buttons and Links not working
  • Palmertree
    • Sep 2005
    • 746
    The following links and buttons are throwing an invalid URI on line 390 causing no action to be taken when clicked:
    • configuration -> hosts -> click on "select" under actions column (menu does not pop-up)
    • graph reset button on charts
    • favorite button "+" or "-" button on both screens and charts
  • bbrendon
    • Sep 2005
    • 873
    Ahhh!! Where did group "All" go?!?!?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      I guess You are talking about pre 1.6.3 ? Well there are two defines introduced (soon will be in pre 1.7.x).
      	define('ZBX_DROPDOWN_FIRST_ENTRY',		0);		// 0 - NONE, 1 - ALL
      	define('ZBX_DROPDOWN_FIRST_REMEMBER',	1);		// 0 - do NOT remember, 1 - do remember
      Zabbix | ex GUI developer
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        Fixed in rev. 6682
        • Palmertree
          • Sep 2005
          • 746
          Aly,
          Thanks for the quick fixes.
          Fixed:
          • Favorites button works great and so does "select" under actions.
          Not working:
          • On the chart reset button, we are getting another error this time on line 213 saying "Object doesn't support this property or method" for charts.php.
          • Also, if you are viewing the configuration of items of host that are template linked items, in the past you could click on the template link in front of the item description and it would send you over to the associate template. Now it just goes to a blank screen.
          Side question:
          I like what you have done with the menu selections for groups and host for "ZBX_DROPDOWN_FIRST_ENTRY". Is there away to keep this to none (unselected) for other screens but have the trigger monitoring screen still show ALL for groups and ALL for host?
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            Only by changing the sources. Those settings are global for frontend..
            • Aly
              ZABBIX developer
              • May 2007
              • 1126
              Aly,
              Not working:
              Thous were 1.7.x specific ones fixed too.
              • Palmertree
                • Sep 2005
                • 746
                Aly,
                The graph reset button and the template link in item configuration is working great in Version Pre 1.7.0 Build 6694. Thanks for the quick fix.
                Other Problems:
                • Configuration -> host -> open host and click the "clone" button it keeps looping.
                • Also group permissions seem like they broke. I rolled back the build before the menu drop down changes and the problem went away. Users that can only see certain groups but not everything, can not see anything in the last few builds.
                Thanks again.
                P.S. The new roll over menu buttons at the top of the screen are awesome. I have had 4 people comment on how they make things easier and faster when switch between Monitoring and Configuration menus. Keep up the good work.
                • Aly
                  ZABBIX developer
                  • May 2007
                  • 1126
                  Other Problems:
                  Should be fixed. Thanks for reporting this
                  • Palmertree
                    • Sep 2005
                    • 746
                    Version Pre 1.7.0 Build 6714 -- Map and Dashboard Bug
                    Aly,
                    Fixed and tested:
                    Host group and permissions are working great. Again thanks for the quick fix.
                    Problem:
                    • A read-only (maybe read-write too) user using IE (tested with version 6) will not be shown the panel screens on the dashboard. "Loading..." is shown and the following error is thrown:
                      Line: 421
                      Object expected
                      URL: site.com/dashboard.php?
                    • Found another issue that will cause a map permission issue and the map will disappear.
                    If you go to "Configuration" -> "Maps" and modify an existing map element of type "host" on a map and change the element from type "Host" to type "Image" and back to type "Host" and save the map element, you will get the following error below:
                    • No host with hostid=[0]
                    Looking at table "sysmaps_elements", I can see that the map element I was modifying, the field "elementid" is getting replaced by "0" and loosing the original "elementid" number.
                    • Palmertree
                      • Sep 2005
                      • 746
                      Aly,
                      Please let me know if you need any additional information for the 2 above issues dealing with Maps and Dashboards in IE. Thanks in advance.
                      • Palmertree
                        • Sep 2005
                        • 746
                        Found the problem with the dashboards in IE not showing up due to object expected error. See code below. Now I just get ')' expected messages in ie about 5 times. Can not figure out were it is coming from.
                        --- pmaster.js.orig     2009-02-15 14:34:27.000000000 -0500
                        +++ pmaster.js  2009-02-16 02:18:10.000000000 -0500
                        @@ -303,7 +303,7 @@
        'method': 'post',
        'parameters': this._params,
        'onSuccess': this.onSuccess.bind(this),
                        -                                               'onFailure': this.onFailure.bind(this),
                        +                                               'onFailure': this.onFailure.bind(this)
                        • Aly
                          ZABBIX developer
                          • May 2007
                          • 1126
                          @@ -303,7 +303,7 @@
        'method': 'post',
                          Yeap, that fixes IE6 problem. But I don't see any error msges in IE6
                          BTW, problem with maps is fixed.
                          • Palmertree
                            • Sep 2005
                            • 746
                            Thanks Aly for the quick fix for Maps.
                            I was going to post this in more detail, but if a user deletes a map that is one of the screens, the screen no longer show under configer or monitoring.
                            • Palmertree
                              • Sep 2005
                              • 746
                              #15
                              Aly your Map updates work great. Thanks again.
                              To fix the screen entry from disappearing mentioned above, I just had to go find the entry in the database sysmap_elements and remove the invalid element id from the screen. Not sure if there is a way to still show the screen if an element is missing or not.
                              Thanks again for the great work as always.
