possible problems with xml export
  • richlv
    • Oct 2005
    • 3112
    i'm seeing some weird issues that i'm unsure about, so let's see who has a better idea
    if the issues can't be resolved/explained here, i'll properly file each as a bugreport.
    1. both trunk & 1.6 branch, revision 6913
    exporting item with key system.cpu.load adds the following value for this item :
    <params>DSN=&lt;database source name&gt;\nuser=&lt;user name&gt;\npassword=&lt;password&gt;\nsql=&lt;query &gt;</params>
    that looks... a bit wrong. is this string supposed to go there ?
    2. for item with key system.cpu.load and item type zabbix agent the following values are also exported, which seem to be both useless and increasing export size :
    <trapper_hosts></trapper_hosts>
    <snmp_community>public</snmp_community>
    <snmp_oid>interfaces.ifTable.ifEntry.ifInOctets. 1</snmp_oid>
    <snmp_port>161</snmp_port>
    <snmpv3_securityname></snmpv3_securityname>
    <snmpv3_securitylevel>0</snmpv3_securitylevel>
    <snmpv3_authpassphrase></snmpv3_authpassphrase>
    <snmpv3_privpassphrase></snmpv3_privpassphrase>
    i also have doubts about exporting of these values :
    <lastlogsize>0</lastlogsize>
    <logtimefmt></logtimefmt>
    3. trunk also exports value <data_type>0</data_type> (for the same item).
    how does this correlate with values in <item type="0" key="system.cpu.load" value_type="0"> ? isn't there some redundancy or something ?
