If an Administrator puts a filter on the audit logs, the filter will never go away unless you delete the session profile key in the database for the user. If the admin does a reset everything is shown. But, if the admin goes to another menu task and comes back to the audit menu the filter is back again. Even if the administrator applies an "ALL" filter it still comes back.
For example:
Goto
"Administration" -> "Audit"
Expand "Filter"
Action = "Add"
Resource = "User"
Select the "Filter" Button
Everything is filtered as designed.
Now, select the "Reset" button.
Everything is reset and shown as designed.
Go to "Administration" -> "Users"
Then go back to "Administration" -> "Audit" and the filter User and Add is back and will not go away.
For example:
Goto
Expand "Filter"
Action = "Add"
Resource = "User"
I flushed my cache and everything.
