This issue was my bad, it is related to the CURL version, not zabbix version.
Made a post about this in help
(http://www.zabbix.com/forum/showthread.php?p=43588)
Please ignore the issue report below.
---------------------8< old message 8<---------------------------------------
OS: Ubuntu 8.04TLS
Zabbix_server is compiled against Curl with GNU-TLS
Since updating to this version, the webchecks are failing.
log snippet
OS: Ubuntu 8.04TLS
log snippet
12603:20090319:115957 Error doing curl_easy_perform [Couldn't connect to server]
12604:20090319:120005 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120012 Error doing curl_easy_perform [Couldn't connect to server]
12604:20090319:120020 Error doing curl_easy_perform [Timeout was reached]
12603:20090319:120027 Error doing curl_easy_perform [Couldn't connect to server]
12604:20090319:120050 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120057 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120112 Error doing curl_easy_perform [Timeout was reached]
12604:20090319:120120 Error doing curl_easy_perform [Timeout was reached]
12603:20090319:120127 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120142 Error doing curl_easy_perform [Couldn't connect to server]
12604:20090319:120150 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120157 Error doing curl_easy_perform [Couldn't connect to server]
12603:20090319:120212 Error doing curl_easy_perform [Timeout was reached]
12603:20090319:120227 Error doing curl_easy_perform [Couldn't connect to server]
12604:20090319:120250 Error doing curl_easy_perform [Couldn't connect to server]
