I am having problems getting alpha11 to compile:
My environment:
Solaris 9
gcc 2.95.3
MySQL 4.0.25 and MySQL 4.1.8
My configure command, which is successful:
LIBS="-lresolv" \
CC=/opt/sfw/bin/gcc \
./configure \
--prefix=/opt/zabbix \
--enable-server \
--with-mysql=/opt/mysql
gmake results, at point of failure:
gmake[3]: Entering directory `/home/clawson/zabbix-1.1alpha11/src/zabbix_server'
source='evalfunc.c' object='evalfunc.o' libtool=no \
DEPDIR=.deps depmode=gcc /bin/bash ../../depcomp \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c evalfunc.c
source='expression.c' object='expression.o' libtool=no \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c expression.c
source='actions.c' object='actions.o' libtool=no \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c actions.c
source='zlog.c' object='zlog.o' libtool=no \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c zlog.c
source='functions.c' object='functions.o' libtool=no \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c functions.c
source='server.c' object='server.o' libtool=no \
/opt/sfw/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include -g -O2 -c server.c
/opt/sfw/bin/gcc -g -O2 -o zabbix_server -L/opt/mysql/lib -lmysqlclient -lm -lz evalfunc.o expression.o actions.o zlog.o functions.o server.o ../libs/zbxsysinfo/libzbxsysinfo.a ../libs/zbxlog/libzbxlog.a ../libs/zbxpid/libzbxpid.a ../libs/zbxconf/libzbxconf.a ../libs/zbxdbhigh/libzbxdbhigh.a ../libs/zbxcrypto/libzbxcrypto.a ../libs/zbxnet/libzbxnet.a pinger/libzbxpinger.a poller/libzbxpoller.a escalator/libzbxescalator.a housekeeper/libzbxhousekeeper.a alerter/libzbxalerter.a timer/libzbxtimer.a trapper/libzbxtrapper.a ../libs/zbxemail/libzbxemail.a ../libs/zbxcommon/libzbxcommon.a -lnsl -lkstat -lsocket -lresolv
Undefined first referenced
symbol in file
mysql_fetch_row ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_data_seek ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_query ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_errno ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_error ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_close ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_insert_id ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_free_result evalfunc.o
mysql_store_result ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_init ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_select_db ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_affected_rows ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_real_connect ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
mysql_num_rows ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
ld: fatal: Symbol referencing errors. No output written to zabbix_server
collect2: ld returned 1 exit status
gmake[3]: *** [zabbix_server] Error 1
gmake[3]: Leaving directory `/home/clawson/zabbix-1.1alpha11/src/zabbix_server'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/home/clawson/zabbix-1.1alpha11/src/zabbix_server'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/clawson/zabbix-1.1alpha11/src'
gmake: *** [all-recursive] Error 1
This looks like a MySQL client problem. I have both the 4.0.25 (latest 4.0 version) and an earlier 4.1.8 version avialable (these are the binary installations--I didn't compile MySQL or use packages). Using either version of MySQL has the same results. With either installation the headers files are available in /opt/mysql/include and libmysqlclient.a is avaliable at /opt/mysql/lib.
Can anyone provide help?
Thanks,
Dan
My environment:
Solaris 9
gcc 2.95.3
LIBS="-lresolv" \
./configure \
--enable-server \
symbol in file
Thanks,
Dan
