1.1Alpha 11 table missing server won't start
  • skendall
    • Jul 2005
    I ran into a problem upgrading from 1.1Alpha10 to 1.1Alpha11 that might help others. The DB upgrade script does not create the needed escalation_log table and it does not exist in the 1.1Alpha10 install schema.
    I used the table add data from the create/mysql/schema.sql script that you would need to import on a new install.
    mysql> CREATE TABLE escalation_log (
    -> escalationlogid int(4) NOT NULL auto_increment,
    -> triggerid int(4) DEFAULT '0' NOT NULL,
    -> alarmid int(4) DEFAULT '0' NOT NULL,
    -> escalationid int(4) DEFAULT '0' NOT NULL,
    -> actiontype int(4) DEFAULT '0' NOT NULL,
    -> level int(4) DEFAULT '0' NOT NULL,
    -> adminlevel int(4) DEFAULT '0' NOT NULL,
    -> nextcheck int(4) DEFAULT '0' NOT NULL,
    -> status int(4) DEFAULT '0' NOT NULL,
    -> PRIMARY KEY (escalationlogid),
    -> KEY (alarmid,escalationid),
    -> KEY (triggerid)
    -> ) type=InnoDB;
    Query OK, 0 rows affected (0.15 sec)
    mysql>
    Without adding this table from an upgrade from 1.1Alpha10 to 1.1Alpha11 the server process won't start and dies with this error.
    007017:20050809:150344 Query::select escalationlogid,triggerid, alarmid, escalationid, level, adminlevel, nextcheck,
    status from escalation_log where status=0 and nextcheck<=1123617824
    007017:20050809:150344 Query failed:Table 'zabbix.escalation_log' doesn't exist [1146]
    007018:20050809:150344 server #5 started [Poller. SNMP:ON]
    007013:20050809:150344 One child process died. Exiting .
    It looks like the upgrades/dbpatches/1.1apcha10_to_1.1apcha11/mysql/patch.sql needs to be updated so that the escalation_log table is added.
