mysql support with 1.1alpha12
  • jpawlowski
    • May 2005
    • 45
    Hi there!
    mysql support seems to have changed in the current version: I cannot use my old style for the configuration parameter of "configure" which is:
    --with-mysql=/usr/local/mysql/current
    The path is a symlink to the current directory of mysql (/usr/local/mysql/4.1.11). After running the configure script the Makefile contains the correct path to the mysqlclient lib (/usr/local/mysql/current/lib/mysql) and in this path a symlink named libmysqlclient.so.14 (which goes to libmysqlclient.so.14.0.0) exists.
    so everything should be fine but I get this startup failure:
    /usr/local/zabbix/current/bin/zabbix_server: error while loading shared libraries: libmysqlclient.so.14: cannot open shared object file: No such file or directory
    how can i solve this problem?
  • primos
    • Jul 2005
    • 61
    Just an idea!
    I compiled --with-mysql without the path as before when I changed my DB to MYSQL 4.1.13 on my SLES 9 box, and no problems what so ever!!
    Maybe if you try adding all the libs before ./configure and perhaps adding --enable-static
    LDLIBS=-lenlibs LDFLAGS=-L/path/to/my/libs ./configure ... --enable-static
    or editing /etc/ld.so.conf to include all the thing you need
    # ldconfig ; to refresh
    and try again!
    My *.so needs for server
    linux-gate.so.1 => (0xffffe000)
    libmysqlclient.so.12 => /usr/lib/libmysqlclient.so.12 (0x40032000)
    libm.so.6 => /lib/tls/libm.so.6 (0x40068000)
    libz.so.1 => /lib/libz.so.1 (0x4008a000)
    libsnmp.so.5 => /usr/lib/libsnmp.so.5 (0x4009b000)
    libcrypto.so.0.9.7 => /usr/lib/libcrypto.so.0.9.7 (0x40124000)
    libnetsnmp.so.5 => /usr/lib/libnetsnmp.so.5 (0x40214000)
    libresolv.so.2 => /lib/libresolv.so.2 (0x4029e000)
    libnsl.so.1 => /lib/libnsl.so.1 (0x402b0000)
    libc.so.6 => /lib/tls/libc.so.6 (0x402c5000)
    libcrypt.so.1 => /lib/libcrypt.so.1 (0x403da000)
    /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
    libdl.so.2 => /lib/libdl.so.2 (0x4040b000)
    • jpawlowski
      • May 2005
      • 45
      I need the direct program path because I do not have my installation in the default directory (as I do not want to have all the files thrown out all over the directories and I can handle the versions in a very better way if I do not).
      those flag definitions are still correct in the Makefile.
      I do not want to have static binaries because it would make a lot of more work to update the system. by the way you even need the libraries once to compile a static version :-)
      my binary does in a similar way...
      • primos
        • Jul 2005
        • 61
        I see you have given it some time.Sorry to waste your time reading my post, I've tried to help.
        ps Maybe zabbix cannot follow link!
        • jpawlowski
          • May 2005
          • 45
          I used the 1.1alpha10 before and that worked fine.
          now i got it working with symlinking that .so-file directly to the directory /usr/lib (although I have an link from /usr/lib/mysql to /usr/local/mysql/current/lib/mysql ...)
          strange behavior
          • primos
            • Jul 2005
            • 61
            I guess you are missing in /etc/ld.so.conf your mysql libs path, correct it then ldconfig should make os aware of the change!
            • jpawlowski
              • May 2005
              • 45
              no I don't want to edit this file all the time. that's why I give the correct path as a parameter to the configure script.
              • grabber
                • Mar 2005
                • 85
                I am encoutering the same problem....any further suggestions?
