there's no way to reorder bar reports' elements - for example, reports -> bar reports, select "Distribution of values for multiple items". add a recent period, then some period in the past, then even more recent period - they are now in the order of the adding sequence, which is almost useless.
there should be reordering support, maybe similar to custom graph item reordering functionality.
same goes for items in this report and the first report (although with items the problem isn't as critical)
