trunk r7571, can't enable auto logout
  • richlv
    • Oct 2005
    • 3112
    auto log out can not be enabled on the current trunk - navigate to the profile, enable auto logout and save changes. revisting the profile & refreshing it shows the option unchecked.
    the value is properly saved in the db, but is not used afterwards
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Thank you, fixed.
    Zabbix | ex GUI developer
    • richlv
      • Oct 2005
      • 3112
      thanks, confirming the fix in trunk, rev 7583
      • richlv
        • Oct 2005
        • 3112
        ok, it actually got even more interesting. trunk, rev 7594 - can't disable autologout anymore
        • Aly
          ZABBIX developer
          • May 2007
          • 1126
          Actually it were disabled, but just didnt show it Check rev. 7596
          • richlv
            • Oct 2005
            • 3112
            ah, yes, i noticed db was updated correctly, but i was logged out before that (because of my previous testing of autologout), so i incorrectly assumed it logged me out even with the option disabled.
            seems to work as expected in trunk, rev 7597
