Zabbix 1.8 - Inventory improvement Petition
  • zabbix_zen
    • Jul 2009
    • 426
    Hi all.
    Though probably the majority of Zabbix users don't fully explore it's Inventory capabilities, (using other software like SugarCRM) it's 'Extended Profile' is quite complete in the number of fields.
    However, selecting 'Inventory -> Hosts' the fields we get aren't much useful if they are the same:
    Host;
    OS(Short);
    HW Architecture;
    Device Type;
    Device Deployment Status;
    ignoring the fields we've already inserted in each Host Extended Profile.
    Is it possible to Improve its 'Mass export' feature of a group of Hosts to Excel? (Currenytly I can only copy paste the Host inventory data to Excel, or query the Hosts Group data from the DB)
    For instance, to be possible for us to personalize which fields will show on 'Inventory -> Hosts (Extended Profile)' or to inteligently only show the Collums that already had Data inserted in 'Configuration -> Hosts', hiding the other collums?)
    Keep up the good work,
    João
  • richlv
    • Oct 2005
    • 3112
    i'd suggest writing up a specific idea and reporting it here https://support.zabbix.com/browse/ZBXNEXT
    ideas could be like "allow to choose visible columns in inventory" and "allow to save visible inventory view as csv"
    • zabbix_zen
      • Jul 2009
      • 426
      Thanks richlv.
      Just followed your recommendation.
      Created it under https://support.zabbix.com/browse/ZBXNEXT-27
