Zabbix 1.1beta1 Add items from template dosen't work
  • jamkad
    • Sep 2005
    • 27
    When i create new host, edit it properties and try to add items from template nothing is added to host. With alpha12 this worked fine. No error is given it only returns to same page
    Is it a bug or am i missing something.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I've got several reports regarding this issue. It seems that it doesn't work in 1.1beta1. Sorry for this.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jporter1
      • Aug 2005
      • 18
      That's alright, we'll forgive you - just tell us when you plan to fix it
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        I'd like to release 1.1beta2 shortly after I get all (including this one) 1.1beta1 issues reported and fixed.
        Will try to make it as stable and easy to use as possible.
        Alexei Vladishev
        My Twitter
        • bbrendon
          • Sep 2005
          • 873
          Being that I just started using zabbix. I messed with alpha12 and upgraded to beta1 and now i'm stuck because this bug is preventing me from adding hosts. any chance to release beta1.1 before beta2 with this problem fixed so we can use it?
          The major bugs i have experienced are:
          -This one
          -win32 agent + event logs (discussed in other threads)
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • Harnak
            • Sep 2005
            -This one
            Yes please a patch for this would be awesome!
            thanks,
            Harnak
            • jporter1
              • Aug 2005
              • 18
              Whilist waiting for the official fix is there anything we can do that will allow us to add servers? How is everyone else working around this? Can we use one of the php pages from the alpha12 release for example? Thanks
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Please wait for 1.1beta2. Hopefully it will be released next Monday.
                Alexei Vladishev
                My Twitter
                • jporter1
                  • Aug 2005
                  • 18
                  Will it appear in the CVS before then? Please say yes
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    Give me a couple of days to fix this issue. I'll keep you informed about any progress made. Yes, it will be available in CVS and possibly in this forum as well.
                    Alexei Vladishev
                    My Twitter
                    • jporter1
                      • Aug 2005
                      • 18
                      Many thanks Alexei. Sorry to keep the pressure on
                      • Harnak
                        • Sep 2005
                        Thanks!
                        This will sure releave some of the pressure my boss has put me under.
                        Is it possible to do this manually via sql or is the problem elsewhere than the frontend?
                        Thanks,
                        Harnak
                        • jporter1
                          • Aug 2005
                          • 18
                          Morning Alexei - any chance of that update please?
                          • Alexei
                            Founder, CEO
                            • Sep 2004
                            • 5654
                            Fixed. Download the latest frontends/php/* from CVS.
                            Alexei Vladishev
                            My Twitter
                            • jporter1
                              • Aug 2005
                              • 18
                              #15
                              Thanks.
