bug in 1.1beta1 - prompt to disable a trigger when im actually deleting
  • mconigliaro
    • Jun 2005
    • 116
    when i try to delete a trigger, it asks me to confirm that i want to DISABLE the trigger. i assume this is a typo.
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    I just checked the source and it is typo. On line 309 in triggers.php, he is querying if you want to disable the triggers, then on line 310, he uses the S_DISABLE_SELECTED_TRIGGERS_Q language constant, instead of the S_DELETE_SELECTED_TRIGGERS_Q language constant.
    EDIT: Attached a patch to fix this
    Unofficial Zabbix Developer
