A few checks not supported by agent on 1.1beta1
  • Siegfried
    • Jul 2005
    • 24
    I'm getting "Not supported by ZABBIX agent" response for the following checks:
    system.cpu.system1
    system.cpu.system5
    system.cpu.system15
    tcp_count
    net.if.1bytes15[eth0]
    kernel.maxproc
    kernel.maxfiles
    Got this from the logs too:
    004599:20050922:115310 Got empty string from [hostname] IP [x.x.x.x] Parameter [system.uname]
    004599:20050922:115310 Assuming that agent dropped connection because of access permissions
    004599:20050922:115310 Host [hostname] will be checked after [60] seconds
    Also getting a "Simple check [check_service[ping,x.x.x.x]] is not supported" error for the ping simple check.
    Any ideas or possible bug? The client was compiled on a CentOS 4 box.
    Thanks again
  • KarmaPolice
    • Oct 2005
    • 95
    the system.cpu.system1 doesn't work in beta2 either. I am curious why just the system one wouldn't work while the idle and user ones do work... seems like it's got to be a bug in the code...
