zabbix 1.7.x import problem
  • Danila
    • May 2006
    • 21
    Import crashes on importing GRAPHS info (hosts without graphs are being importred successfully)
    Error is:
    * Added new host [Template_AP_Canopy]
    * pg_fetch_assoc() expects parameter 1 to be resource, boolean given[/var/www/new/include/db.inc.php:547]
    * Added new item Template_AP_Canopy:ifInOctets1
    * Added new item Template_AP_Canopy:ifInUcastPkts.1
    * Added new item Template_AP_Canopy:ifOutOctets1
    * Added new item Template_AP_Canopy:ifOutUcastPkts.1
    * Undefined index: hostid[/var/www/new/api/classes/class.citem.php:549]
    * pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: ошибка синтаксиса в конце ввода LINE 1: ...temid FROM items i WHERE i.key_='ifOutOctets1' AND i.hostid= ^[/var/www/new/include/db.inc.php:406]
    * Error in query [SELECT DISTINCT i.itemid FROM items i WHERE i.key_='ifOutOctets1' AND i.hostid=] [ERROR: ошибка синтаксиса в конце ввода LINE 1: ...temid FROM items i WHERE i.key_='ifOutOctets1' AND i.hostid= ^]
    * reset() [<a href='function.reset'>function.reset</a>]: Passed variable is not an array or object[/var/www/new/include/export.inc.php:847]
    * pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: ошибка синтаксиса в конце ввода LINE 1: ...itemid FROM items i WHERE i.key_='ifInOctets1' AND i.hostid= ^[/var/www/new/include/db.inc.php:406]
    * Error in query [SELECT DISTINCT i.itemid FROM items i WHERE i.key_='ifInOctets1' AND i.hostid=] [ERROR: ошибка синтаксиса в конце ввода LINE 1: ...itemid FROM items i WHERE i.key_='ifInOctets1' AND i.hostid= ^]
    * pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: current transaction is aborted, commands ignored until end of transaction block[/var/www/new/include/db.inc.php:406]
    * Error in query [SELECT g.graphid FROM graphs g, graphs_items gi, items i WHERE g.graphid=gi.graphid AND gi.itemid=i.itemid AND g.name='Ethernet Traffic' AND i.hostid=10049] [ERROR: current transaction is aborted, commands ignored until end of transaction block]
    * pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: ошибка синтаксиса в конце ввода LINE 1: ...d FROM items i WHERE i.key_='ifOutUcastPkts.1' AND i.hostid= ^[/var/www/new/include/db.inc.php:406]
    * Error in query [SELECT DISTINCT i.itemid FROM items i WHERE i.key_='ifOutUcastPkts.1' AND i.hostid=] [ERROR: ошибка синтаксиса в конце ввода LINE 1: ...d FROM items i WHERE i.key_='ifOutUcastPkts.1' AND i.hostid= ^]
    * pg_query() [<a href='function.pg-query'>function.pg-query</a>]: Query failed: ERROR: ошибка синтаксиса в конце ввода LINE 1: ...id FROM items i WHERE i.key_='ifInUcastPkts.1' AND i.hostid= ^[/var/www/new/include/db.inc.php:406]
    * Error in query [SELECT DISTINCT i.itemid FROM items i WHERE i.key_='ifInUcastPkts.1' AND i.hostid=] [ERROR: ошибка синтаксиса в конце ввода LINE 1: ...id FROM items i WHERE i.key_='ifInUcastPkts.1' AND i.hostid= ^]
    * Undefined index: gitems[/var/www/new/api/classes/class.cgraph.php:447]
    * Missing items for graph "IP Traffic"
    XML attached
  • Danila
    • May 2006
    • 21
    I'm using debian lenny and postgresql 8.3.8
    • richlv
      • Oct 2005
      • 3112
      could you please test with latest trunk and report on the tracker if the problem is still present ?
      • Danila
        • May 2006
        • 21
        In trunk versions import works. 3 buggable moments exsit:
        1. # Item '_1801:ifInOctets.1' updated
        # pg_fetch_assoc() expects parameter 1 to be resource, boolean given[/var/www/trunk/include/db.inc.php:547]
        2. Undefined index: graphid[/var/www/trunk/api/classes/class.cgraph.php:595]
        3. New hostgroups are not created automaticaly with hosts. This feature was not inclued in 1.6 versions but it'd be very useful to have it in 1.7.
        is it possible to use frontend from trunk with 1.7.2 database?
        thnx!
        • richlv
          • Oct 2005
          • 3112
          could you report these on the tracker, indicating exact revision and attaching test import file ?
          please search feature requests, if not present, add one
          ouch... that's a huge font.
          while it should be mostly possible, there might be some changes to the database schema.
          compare the two revisions, and check this thread for any (unsupported ) patches :
