I had some problems using the upgrade script on my 1.6.6 database where it complained the SQL syntax was not understood by mysql 5.0.77. I removed some of the offending lines and now everything seems to be working except creating a new template:
Have I messed up the database?
One line in mysql/patch.sql it was complaining about was:
There were a couple of other similar lines as well...
* Added new host [App_Dns]
* Error in query [SELECT DISTINCT h.hostid,h.host FROM hosts_templates ht LEFT JOIN hosts h ON h.hostid=ht.templateid WHERE ht.hostid=Array ORDER BY h.host] [Unknown column 'Array' in 'where clause']
* mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource[/usr/lfs/v0/apps/zabbix/1.7.2/php/include/db.inc.php:544]
* Undefined index: hosts[/usr/lfs/v0/apps/zabbix/1.7.2/php/api/classes/class.ctemplate.php:802]
* Undefined index: templates[/usr/lfs/v0/apps/zabbix/1.7.2/php/api/classes/class.ctemplate.php:803]
* DBcondition Error: [hostid] =
* DBcondition Error: [templateid] =
* Invalid argument supplied for foreach()[/usr/lfs/v0/apps/zabbix/1.7.2/php/api/classes/class.ctemplate.php:819]
* Invalid argument supplied for foreach()[/usr/lfs/v0/apps/zabbix/1.7.2/php/api/classes/class.ctemplate.php:835]
* Error in query [SELECT h.* FROM hosts h, hosts_templates ht WHERE h.hostid=ht.hostid AND (ht.templateid IN (10109,0,App_Dns,,0,0.0.0.0,0,3,0,,0,0,0,0,0,1,623,0,0,,,0,0,0,0,0,0,0,0,,0,0,10109)) ] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '0,0.0.0.0,0,3,0,,0,0,0,0,0,1,623,0,0,,,0,0,0,0,0,0,0,0,,0,0,10109))' at line 1]
* Error in query [SELECT host FROM hosts WHERE hostid=Array] [Unknown column 'Array' in 'where clause']
alter table graphs_items alter color varchar(6) DEFAULT '009600' NOT NULL;
mysql> alter table graphs_items alter color varchar(6) DEFAULT '009600' NOT NULL; ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'varchar(6) DEFAULT '009600' NOT NULL' at line 1
