Zoom on a graph
  • Filter
    Zoom on a graph
    It's not possible to zoom on a graph on a range lower than 1 hour. (and it still not possible by clicking and selecting the range we would like to see)
    Is it normal ?
    Thank you.
    Philippe.
    yes, one hour is the minimal graph period
    Zabbix tips and inspiration (blog)
      1h maximum zoom is not enough
      Hi
      I think zooming feature is very important and 1h maximum zoom is not enough for hosts with interval 5 second, because in 1 hour zabbix gets 720 values!!
      Is there any module can increase this feature??
      Thanks in advance
        5 second interval sounds too short for most sane installations.
        if you really need it and if you really know what you are doing, see http://www.zabbix.com/documentation/...config/defines, ZBX_MIN_PERIOD
          Hi richlv.
          Is there some other config or action that I am supposed to make to get this functionality working? I've changed the ZBX_MIN_PERIOD to "600" (10 min) and the graphs continue to accept only "1 h" as minimum zoom period. Even if I logout and login again the change doesn't take effect.
            hmm. no idea, i've never actually tried to change it myself
              There is a similar issue with a ZBX_MAX_PERIOD... I can set it to 3*365*86400 but there is no way to view last 3 year period on a single graph.
              There are calendar option to specify the date, but when either date is changed, it resets the other one to the same year and only way to see older data, is to "scroll" left using «« markers.
                did you try changing dates withing the calendar popups with mode switched to "dynamic" ?
                  Hi Richlv. For me, this didn't work! Maybe this issue deserves a bug applying on the tracker.
                    if using dynamic mode calendar does not set the date to whatever time you choose (assuming there's data), that's a bug and should be reported on the tracker. before doing so, please try to reproduce the problem with svn head version, thanks.
                      I've tested svn head version and the problem persists. I'll create an issue on the tracker.
                        Everyone is welcome to vote:
                        https://support.zabbix.com/browse/ZBX-2517
                          Using dynamic mode together with ZBX_MAX_PERIOD worked me. Now I could view 3 years data, tnx. Tested with 1.8.2 stable.
                            Hello all,
                            I was also in need of shorter time periods in graphs.
                            I suspect the vars in the define file are left from the time Zabbix used the old graphing system.
                            I adjusted the values in js/gtlc.js and it seems to work for me.
                            Here is a diff between the old and new version of the file:
                            linux-epfq:/usr/share/zabbix # diff js/gtlc.js.bak js/gtlc.js
                            67c67
                            <       if(!isset('period', time))              time.period = 3600;
                            >       if(!isset('period', time))              time.period = 300;
                            273c273
                            <       var period = 3600;
                            >       var period = 300;
                            421c421
                            < minperiod: 3600,                              // minimal allowed period
                            > minperiod: 300,                               // minimal allowed period
                            1492c1492
                            <       var zooms = [3600, (2*3600), (3*3600), (6*3600), (12*3600), 86400, (7*86400), (14*86400), (30*86400), (90*86400), (180*86400), (365*86400)];
                            >       var zooms = [300, 3600, (2*3600), (3*3600), (6*3600), (12*3600), 86400, (7*86400), (14*86400), (30*86400), (90*86400), (180*86400), (365*86400)];
                            1529c1529
                            <       var moves = [3600, (12*3600), 86400, (7*86400), (30*86400), (180*86400), (365*86400)];
                            >       var moves = [300, 3600, (12*3600), 86400, (7*86400), (30*86400), (180*86400), (365*86400)];
                            I hope it's useful to someone.
                            With kind regards,
                            Raymond
                            Online Zabbix tutorials:
                            http://www.zbxtutorials.org
                              more zoom!
                              Thanks to qix, I was able to get what I wanted. All I was looking for was more zoom than one hour.
                              I just made a modification to one of the lines he referenced.
                              On line 421 of /usr/share/zabbix/js/gtlc.js I set minperiod to 60 seconds instead of 3600.
                              Update:
                              After a reinstall, I realized there was one other change that made this possible:
                              On line 32 of /usr/share/zabbix/include/defines.inc.php I set ZBX_MIN_PERIOD to match (60 seconds).
                              Originally posted by qix View Post
                              Hello all,
                              67c67
                              273c273
                              >       var period = 300;
                              421c421
                              1492c1492
                              1529c1529
                              Announcement
                              No announcement yet.
