1.1beta1, no latest data
  • sles
    • Oct 2005
    • 80
    Hello!
    I just installed 1.1beta1 on SLES9 instead of 1.0.
    I did fresh install.
    I created host in configuration-host using ip address.
    Agent and server are on the same host
    And I see that Availability is unknown.
    And there is no this host in latest values.
    I changed zabbix_agent to zabbix_agetnt(active) - still Availability is unknown.
    Host appeared in latest values, but no values.
    I see that agent is writing values to /tmp , but I see no insert statements in server log (with loglevel 4).
    btw, which value has to be in zabbix_agentd.conf for Hostname?
    I have it set to localhost, but if I set it for real hostname agentd crashes.
    All I see is:
    010797:20051011:131750 zabbix_agentd started. ZABBIX 1.1beta1.
    010798:20051011:131750 zabbix_agentd 10798 started
    010799:20051011:131750 zabbix_agentd 10799 started
    010800:20051011:131750 zabbix_agentd 10800 started
    010802:20051011:131750 zabbix_agentd 10802 started
    010802:20051011:131750 In init_list()
    010802:20051011:131750 In refresh_metrics()
    010802:20051011:131750 get_active_checks: host[192.168.22.254] port[10051]
    010801:20051011:131750 zabbix_agentd 10801 started
    010802:20051011:131750 Sending [ZBX_GET_ACTIVE_CHECKS
    gopher
    010802:20051011:131750 Before read
    010802:20051011:131750 In delete_all_metrics()
    010802:20051011:131750 Parsed [:30:0]
    010802:20051011:131750 Key [30]
    010802:20051011:131750 Refresh [0]
    010802:20051011:131750 Lastlogsize [(null)]
    010797:20051011:131750 One child process died. Exiting ...
    010798:20051011:131750 Got signal. Exiting ...
    010799:20051011:131750 Got signal. Exiting ...
    010800:20051011:131750 Got signal. Exiting ...
    010801:20051011:131750 Got signal. Exiting ...
    Any ideas?
  • sles
    • Oct 2005
    • 80
    OK. Problem is in agent.
    I created host called localhost and agent dies with absolutely the same messages in log as with hostname="real hostname".
    Something is broken in data transfer...
