Zabbix Server 1.1beta2 hangs on startup
  • chocho63
    • Jun 2005
    • 53
    I can't load zabbix_server 1.1beta2. I hangs with error :
    025105:20051013:153752 server #6 started [Trapper]
    025100:20051013:153752 Query::select escalationlogid,triggerid, alarmid, escalationid, level, adminlevel, nextcheck, status from escalation_log where status=0 and nextcheck<=1129210672
    025100:20051013:153752 Query failed:Table 'zabbix.escalation_log' doesn't exist [1146]
    025106:20051013:153752 server #7 started [Trapper]
    025070:20051013:153752 One child process died. Exiting ...
    025107:20051013:153752 server #8 started [Trapper]
    025070:20051013:153752 Got QUIT or INT or TERM or PIPE signal. Exiting...
    025107:20051013:153752 Got QUIT or INT or TERM or PIPE signal. Exiting...
    The table escalation_log doesn't exist.
    I've applied patch.sql.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    What ZABBIX version you're upgrading from?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • chocho63
      • Jun 2005
      • 53
      Pb Zabbix Server
      I'm upgrading from 1.1alpha11 to 1.1beta2, but I've applied patch.sql for 1.1apha11 to 1.1alpha12, 1.1alpha12 to 1.1beta1 and 1.1beta1 to 1.1beta2.
      • chocho63
        • Jun 2005
        • 53
        Pb Zabbix Server
        I've found the solution : the creation of escalation_log is found in 1.1alpha10 to 1.1alpha11 patch.sql. My first version of Zabbix was 1.1alpha10, but I've already applied patch.sql, I don't understand.
        • marc
          • Oct 2004
          • 146
          sounds a bit like an sql error on applying the patch.
          i tricked myself by ignoring a mysql error applying patch to 1.1beta2. i added the new autoreg table from cvs and my cat patch.sql | mysql ... failed because existing table. server aint startet because the new 'ALTER" statements were missing.
          this is just an example because seems like you just forgot something.
          set Debuglevel 4 in zabbix_server.conf and check Logfile for missing columns or tables.
