Zabbix_suckerd randomly stops
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    #31
    I'd like to add that the problem happens only in case if a notification contains a macro referring an item having custom multiplier defined.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Tarball
      • Feb 2005
      I'm having a similar problem on a fresh install -- never used zabbix before. This is 1.1 alpha 5 downloaded from the website -- not a cvs copy.
      Mysql/php parts are all configured, seem to work fine.
      I try to start the zabbix server, and I get this:
      031606:20050204:155423 Starting zabbix_server...
      031608:20050204:155423 #server 1 started [Alerter]
      031609:20050204:155423 server #2 started [nodata() calculator]
      031611:20050204:155423 server #3 started [ICMP pinger]
      031615:20050204:155423 server #5 started [Trapper]
      031616:20050204:155423 server #6 started [Trapper]
      031606:20050204:155423 One child process died. Exiting ...
      031606:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031608:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031609:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031611:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031613:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031615:20050204:155423 Got QUIT or INT or TERM or PIPE signal. Exiting...
      031615:20050204:155423 Cannot remove PID file [/var/tmp/zabbix_server.pid] [No such file or directory]
      I tried turning the debug level to 4, but it didn't seem to provide any additional useful information. I haven't modified anything other than some user permissions and attempted to add a host through the web interface.
      Any thoughts?
      • Rick LEE
        • Dec 2004
        I've run zabbix on FreeBSD 4.10 installed with package. Some day ,I think when MySQL database size was reached almost 1GB, suckerd's one child process died. I've change many thing in suckerd.conf file however I still have this problem. I usually see bellow message when the process died.
        033569:20050407:091831 zabbix_suckerd #9 started [Sucker. SNMP:ON]
        033568:20050407:110825 Query::select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i
        .snmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.pre vvalue,i.hostid,h.status,i.value_type,h.network_er rors,i.snmp_port,i.delta,i
        .prevorgvalue,i.lastclock from items i,hosts h where i.nextcheck<=1112839705 and i.status=0 and i.type not in (2) and (h.statu
        s=0 or (h.status=2 and h.disable_until<=1112839705)) and h.hostid=i.hostid and i.itemid%6=4 and i.key_<>'status' and i.key_<>'
        icmpping' and i.key_<>'icmppingsec' order by i.nextcheck
        033568:20050407:110825 Query failed:Lost connection to MySQL server during query [2013]
        033560:20050407:110825 One child process died. Exiting ...
        033561:20050407:110825 Got QUIT or INT or TERM or PIPE signal. Exiting...
        033562:20050407:110825 Got QUIT or INT or TERM or PIPE signal. Exiting...
        • klavs
          • Apr 2005
          • 18
          #34
          I've posted a bug about zabbix_serverd (and probably also suckerd from 1.0 release) dieing, when mysql is restarted. Perhaps this is what happens here?
