win32: cpu_util vs. system[procload]
  • Tys
    • Oct 2005
    just a question, I hope, i won't be a bug.
    In the host template Host.Win32 an item called "system[procload]" is defined.
    On 'some' of the monitored servers, it shows a cpu load that is too high.
    The 1.1alpha documentation tells me to use cpu_util for win32 systems, which seems to show the correct cpu utilization.
    Maybe you should update that item on the template..
    hth, Tys
    /edit/
    Well, wrong order again, I just read the 1.0 documentation. It tells me, that system[procload] is not percentage.
    Not that I know now that it is given in Tzulanbesi Gordans or similar units, at least I know it's not percentage
    Zabbix 1.1beta2, upgraded from Zabbix1.1beta1
