zabbix_server is running but web page reports it's not
  • avenueb
    • Feb 2005
    • 12
    This is a new install on FC4.
    When I login to the web page-
    Status of ZABBIX
    ZABBIX server is running No
    However, zabbix_server is indeed running:
    [root@boston zabbix]# ps -ef | grep zabbix
    zabbix 833 1 0 Oct30 ? 00:00:04 ./zabbix_agentd
    zabbix 834 833 0 Oct30 ? 00:00:00 ./zabbix_agentd
    zabbix 835 833 0 Oct30 ? 00:00:00 ./zabbix_agentd
    zabbix 836 833 0 Oct30 ? 00:00:00 ./zabbix_agentd
    zabbix 837 833 0 Oct30 ? 00:00:00 ./zabbix_agentd
    zabbix 838 833 0 Oct30 ? 00:00:00 ./zabbix_agentd
    zabbix 3034 1 1 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3036 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3038 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3040 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3043 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3045 3034 1 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3046 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3047 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3052 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3054 3034 0 00:28 ? 00:00:00 ./zabbix_server
    zabbix 3056 3034 0 00:28 ? 00:00:00 ./zabbix_server
    Thoughts?
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, I suspect that you are running the frontend on a different machine than the Zabbix server itself.
    Unofficial Zabbix Developer
    • avenueb
      • Feb 2005
      • 12
      same host
      Originally posted by James Wells
      Greetings,
      actually no, the zabbix_server is running on the same machine as the web frontend.
      One thing I did do is there was another post about how best to set up zabbix on a FC4 server, following the instructions there I had copied my zabbix binaries to /opt/zabbix/ and have started the zabbix_server (and agent) process from there.
      Could that be an issue?
      • elkor
        • Jul 2005
        • 299
        I had this issue. It resolved itself at some point so I never got around to investigating it.
        As I could clearly see that zabbix_server was running I wasn't too worried about it and it was a very low priority.
        • Nate Bell
          • Feb 2005
          • 141
          Well, the command that Zabbix uses to find if the server is running is the following:
          if( (exec("ps -ef|grep zabbix_server|grep -v grep|wc -l")>0) ||
          (exec("ps -ax|grep zabbix_server|grep -v grep|wc -l")>0) )
          and from the look of your ps -ef output, the first conditional should be met. If you are able to collect data, and everything seems to be functioning, I don't think this is a problem. And as happened with elkor, your server may suddenly figure out that Zabbix is running.
          Nate
