Steps to reproduce:
1. Define two items, "testasis" and "testdelta".
Description/key "testasis" and "testdelta"
host: localhost
type: "Zabbix trapper".
testasis should have the Store value: As is
testdelta should have the Store value: Delta (speed per second)
2. Use the zabbix_sender commands as below:
[zabbix@nms zabbix]$ /opt/zabbix/bin/zabbix_sender localhost 10051 localhost testasis 10
OK
[zabbix@nms zabbix]$ /opt/zabbix/bin/zabbix_sender localhost 10051 localhost testdelta 10
OK
3. Create a graph for the two items above
The problem is that only testasis updates the graph I have defined.
The values in the graph changes to:
testasis [min:10 max:10 last:10]
testdelta [min:0 max:0 last:0]
Teh values for testdelta remains at 0.
Logfiles below
*******testasis********
021657:20051108:210753 After accept()
021657:20051108:210753 Before read()
021657:20051108:210753 After read() 2 [107]
021657:20051108:210753 Got line:<req><host>bG9jYWxob3N0</host><key>dGVzdGFzaXM=</key><data>MTA=</data><lastlogsize
>MA==</lastlogsize></req
021657:20051108:210753 Trapper got [<req><host>bG9jYWxob3N0</host><key>dGVzdGFzaXM=</key><data>MTA=</data><lastlog
size>MA==</lastlogsize></req]
021657:20051108:210753 XML received [<req><host>bG9jYWxob3N0</host><key>dGVzdGFzaXM=</key><data>MTA=</data><lastlo
gsize>MA==</lastlogsize></req]
021657:20051108:210753 In process_data([localhost],[testasis],[10],[0])
021657:20051108:210753 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.ty
pe,i.snmp_community,i.snmp_oid,h.useip,h.ip,i.hist ory,i.lastvalue,i.prevvalue,i.value_type,i.trapper _hosts,i.delta
,i.units,i.multiplier,i.formula,i.logtimefmt from items i,hosts h where h.status=0 and h.hostid=i.hostid and h.hos
t='localhost' and i.key_='testasis' and i.status=0 and i.type in (2,7)
021657:20051108:210753 In DBnum_rows
021657:20051108:210753 Result of DBnum_rows [1]
021657:20051108:210753 Processing [10]
021657:20051108:210753 In process_new_value()
021657:20051108:210753 In add_history()
021657:20051108:210753 Executing query:insert into history (clock,itemid,value) values (1131480473,17879,10.000000
021657:20051108:210753 In add_trend()
021657:20051108:210753 SQL [select num,value_min,value_avg,value_max from trends where itemid=17879 and clock=1131
480000]
021657:20051108:210753 Executing query:select num,value_min,value_avg,value_max from trends where itemid=17879 and
clock=1131480000
021657:20051108:210753 Executing query:insert into trends (clock,itemid,num,value_min,value_avg,value_max) values
(1131480000,17879,1,10.000000,10.000000,10.000000)
021657:20051108:210753 Executing query:update items set nextcheck=1131480480,prevvalue=lastvalue,lastvalue ='10',la
stclock=1131480473 where itemid=17879
021657:20051108:210753 In update_functions(17879)
021657:20051108:210753 Executing query:select function,parameter,itemid,lastvalue from functions where itemid=1787
9 group by 1,2,3 order by 1,2,3
021657:20051108:210753 In update_triggers [17879]
021657:20051108:210753 Executing query:select distinct t.triggerid,t.expression,t.status,t.dep_level,t.pr iority,t.
value,t.description from triggers t,functions f,items i where i.status<>3 and i.itemid=f.itemid and t.status=0 and
f.triggerid=t.triggerid and f.itemid=17879
021657:20051108:210753 Sending back [OK
*******testdelta********
021652:20051108:210814 After accept()
021652:20051108:210814 Before read()
021652:20051108:210814 After read() 2 [107]
021652:20051108:210814 Got line:<req><host>bG9jYWxob3N0</host><key>dGVzdGRlbHRh</key><data>MTA=</data><lastlogsize
021652:20051108:210814 Trapper got [<req><host>bG9jYWxob3N0</host><key>dGVzdGRlbHRh</key><data>MTA=</data><lastlog
021652:20051108:210814 XML received [<req><host>bG9jYWxob3N0</host><key>dGVzdGRlbHRh</key><data>MTA=</data><lastlo
021652:20051108:210814 In process_data([localhost],[testdelta],[10],[0])
021652:20051108:210814 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.ty
t='localhost' and i.key_='testdelta' and i.status=0 and i.type in (2,7)
021652:20051108:210814 In DBnum_rows
021652:20051108:210814 Result of DBnum_rows [1]
021652:20051108:210814 Processing [10]
021652:20051108:210814 In process_new_value()
021652:20051108:210814 In add_history()
021652:20051108:210814 Executing query:insert into history (clock,itemid,value) values (1131480494,17880,0.000000)
021652:20051108:210814 In add_trend()
021652:20051108:210814 SQL [select num,value_min,value_avg,value_max from trends where itemid=17880 and clock=1131
480000]
021652:20051108:210814 Executing query:select num,value_min,value_avg,value_max from trends where itemid=17880 and
clock=1131480000
021652:20051108:210814 Executing query:insert into trends (clock,itemid,num,value_min,value_avg,value_max) values
(1131480000,17880,1,0.000000,0.000000,0.000000)
021652:20051108:210814 Executing query:update items set nextcheck=1131480510,prevvalue=lastvalue,prevorgva lue=10.0
00000,lastvalue='0.000000',lastclock=1131480494 where itemid=17880
021652:20051108:210814 In update_functions(17880)
021652:20051108:210814 Executing query:select function,parameter,itemid,lastvalue from functions where itemid=1788
0 group by 1,2,3 order by 1,2,3
021652:20051108:210814 In update_triggers [17880]
021652:20051108:210814 Executing query:select distinct t.triggerid,t.expression,t.status,t.dep_level,t.pr iority,t.
f.triggerid=t.triggerid and f.itemid=17880
021652:20051108:210814 Sending back [OK
Any help on this is very much appreciated.
Robert
host: localhost
OK
OK
Logfiles below
480000]
clock=1131480000
480000]
clock=1131480000
Robert
