pre-zabbix-1.8.3.x-12788
  • ruswold
    • Mar 2010
    • 210
    I have installed zabbix 1.8.2 stable from ports on FreeBSD 8.0
    When I install from sources pre-zabbix-1.8.3.x-12788 and run zabbix server, i found that zabbix server don't start and in log:
    58355:20100616:172325.312 Starting Zabbix Server. Zabbix 1.8.3 (revision 12779).
    58355:20100616:172325.312 **** Enabled features ****
    58355:20100616:172325.312 SNMP monitoring: YES
    58355:20100616:172325.312 IPMI monitoring: NO
    58355:20100616:172325.312 WEB monitoring: YES
    58355:20100616:172325.312 Jabber notifications: YES
    58355:20100616:172325.312 ODBC: YES
    58355:20100616:172325.312 SSH2 support: YES
    58355:20100616:172325.312 IPv6 support: NO
    58355:20100616:172325.313 **************************
    58355:20100616:172327.394 server #0 started [Watchdog]
    58356:20100616:172327.395 server #1 started [DB Cache]
    58365:20100616:172327.433 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58365:20100616:172327.433 ====== Fatal information: ======
    58365:20100616:172327.433 program counter not available for this architecture
    58365:20100616:172327.433 === Registers: ===
    58365:20100616:172327.433 register dump not available for this architecture
    58365:20100616:172327.433 === Backtrace: ===
    58365:20100616:172327.433 backtrace not available for this platform
    58365:20100616:172327.433 === Memory map: ===
    58365:20100616:172327.433 memory map not available for this platform
    58365:20100616:172327.433 ================================
    58366:20100616:172327.435 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58366:20100616:172327.436 ====== Fatal information: ======
    58366:20100616:172327.436 program counter not available for this architecture
    58366:20100616:172327.436 === Registers: ===
    58366:20100616:172327.436 register dump not available for this architecture
    58366:20100616:172327.436 === Backtrace: ===
    58366:20100616:172327.436 backtrace not available for this platform
    58366:20100616:172327.436 === Memory map: ===
    58366:20100616:172327.436 memory map not available for this platform
    58366:20100616:172327.436 ================================
    58357:20100616:172327.464 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58357:20100616:172327.464 ====== Fatal information: ======
    58357:20100616:172327.464 program counter not available for this architecture
    58357:20100616:172327.464 === Registers: ===
    58357:20100616:172327.464 register dump not available for this architecture
    58357:20100616:172327.464 === Backtrace: ===
    58357:20100616:172327.464 backtrace not available for this platform
    58357:20100616:172327.464 === Memory map: ===
    58357:20100616:172327.464 memory map not available for this platform
    58357:20100616:172327.464 ================================
    58377:20100616:172327.469 server #22 started [Trapper]
    58379:20100616:172327.469 server #24 started [Trapper]
    58381:20100616:172327.470 server #26 started [Trapper]
    58383:20100616:172327.470 server #28 started [Alerter]
    58385:20100616:172327.470 server #30 started [Timer]
    58387:20100616:172327.470 server #32 started [HTTP Poller]
    58389:20100616:172327.470 server #34 started [DB Syncer]
    58391:20100616:172327.471 server #36 started [DB Syncer]
    58393:20100616:172327.471 server #38 started [Escalator]
    58355:20100616:172327.471 One child process died (PID:58365,exitcode/signal:65280). Exiting ...
    58372:20100616:172327.471 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58356:20100616:172327.471 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58374:20100616:172327.472 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58359:20100616:172327.472 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58376:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58361:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58363:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58378:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58367:20100616:172327.474 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58382:20100616:172327.474 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58369:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58384:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58371:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58386:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58373:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58388:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58375:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58377:20100616:172327.477 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58390:20100616:172327.477 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58379:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58392:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58381:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58358:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58383:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58362:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58360:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58385:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58364:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58387:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58368:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58389:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58370:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58391:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58380:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58393:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58355:20100616:172329.484 Syncing history data...
    58355:20100616:172329.484 Syncing history data... done.
    58355:20100616:172329.484 Syncing trends data...
    58355:20100616:172329.484 Syncing trends data... done.
    58355:20100616:172329.484 Zabbix Server stopped. Zabbix 1.8.3 (revision 12779).
    What is it "program counter not available for this architecture" and zabbix server don't start?
  • richlv
    • Oct 2005
    • 3112
    interesting. please report it on the tracker
    • ruswold
      • Mar 2010
      • 210
      Ok, https://support.zabbix.com/browse/ZBX-2559
      • ruswold
        • Mar 2010
        • 210
        make portupgrade net-snmp to version 5.5, it's resolv problem
        • ruswold
          • Mar 2010
          • 210
          new problem with pre-zabbix-1.8.3.x-12896
          1. When i make search host with "QUICK SEARCH", appear error
          Undefined index: excludePattern[/usr/local/www/apache22/data/api/classes/class.chost.php:459]
          • richlv
            • Oct 2005
            • 3112
            thanks, this should be fixed now. btw, it's better to report problems on the tracker, because then there's less chance for them to go unnoticed
            • ruswold
              • Mar 2010
              • 210
              OK, https://support.zabbix.com/browse/ZBX-2578
