icmpping and icmppingsec giving same information
  • jamkad
    • Sep 2005
    • 27
    item configuration:
    icmpping icmpping 30 90 365 Simple check Active Simple check
    icmppingsec icmppingsec 60 90 365 Simple check Active Simple check
    latest data:
    DESCRIPTION Last check Last value Change History
    icmpping 11 Dec 14:00:39 0.37 +0.02 Graph
    icmppingsec 11 Dec 14:00:39 0.46 -1.99 Graph
    In zabbix 1.1 help it says that icmpping should return 0 or 1:
    icmpping: Checks if server accessible by ICMP ping
    0 - ICMP ping fails 1 - ICMP ping successful
    Is this a bug or am i doing something wrong?
    Is there another way to get information if host is down using
    simple check? I would like have trigger to inform me when host
    is down and with icmppingsec i can't get it working.
    thanks
  • pdwalker
    • Dec 2005
    • 166
    in 1.1b3, I am not having that problem.
    icmpping is returning 1 or 0
    icmppingsec is returning a time.
    Can you verify your rules one more time?
    - Paul
    • pdwalker
      • Dec 2005
      • 166
      My apologies!
      icmpping is *not* working in 1.1b3. No data is being stored into the database for icmpping.
      A number is being displayed (0.16??) but there are no entries in the history table.
      icmppingsec is working and entries are being stored into the database.
      I'll test in 1.1b4 later today.
      - Paul
      • pdwalker
        • Dec 2005
        • 166
        Not working in 1.1b4 either. It did work for me in 1.1b2.
        Type:
        Simple Check
        key:
        icmpping
        units:
        <empty>
        use multiplier:
        do not use
        type of information:
        numeric
        store value:
        as is
        • Nate Bell
          • Feb 2005
          • 141
          Wow, I'm glad you guys found this bug before I switched to Beta4 since I use icmpping to detect if our machines are up or down. That's a deal breaker for me until it gets resolved. Thanks for the heads up.
          • pdwalker
            • Dec 2005
            • 166
            You can try agent.ping for those machines with a zabbix client
            • illumin8
              • Jun 2005
              • 36
              Ironically the alpha versions are much more stable than any of the beta versions I've seen. At least in the alpha versions templating worked and icmpping worked.
              Ouch... time to deploy alpha 10
              • jamkad
                • Sep 2005
                • 27
                i hope this will be fixed for beta5
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  I cannot confirm this issue in 1.1beta4 yet. Will be tested and fixed if needed.
                  Alexei Vladishev
                  New York | Tokyo | Riga
                  My Twitter
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    Yes, both icmpping and icmppingsec are broken in 1.1beta4. Sorry for this.
                    Please wait for ZABBIX 1.1beta5 or download the latest pinger.c from CVS and recompile it with 1.1beta4 sources.
                    Alexei Vladishev
                    My Twitter
                    • rushowr
                      • Jul 2005
                      • 30
                      Here's a simple script you can run on the monitoring server (via the agent, using a custom parameter) that will emulate the exact same functionality. Just thought I'd share, since I've been officially reamed a new posterier over this today. I had missed the fact that it was broken, and got a chewing over a 5 hour downtime due to the lack of this item.
                      #! /bin/bash
                      /usr/sbin/fping $1 | grep alive | wc -l
                      Run this with a user parameter like:
                      UserParameter=alivecheck.[HOSTNAME],/path/to/script.sh [HOSTNAME]
