beta5 reports traffic incorrectly in some cases
  • bbrendon
    • Sep 2005
    • 873
    After upgrading from beta2 to beta5, I have one SNMP 1 (tried 2 as well) item that doesn't work.
    Type: I tried it as numberc 64 and float.
    Store value: delta (speed per sec)
    No multipliers are used
    Units are set to "bps"
    Snmpget reports it as:
    IF-MIB::ifOutOctets.16777219 = Counter32: 3114709372
    Zabbix reports: 3689348614.51 Gbps
    I tried deleting and recreating the item, no luck. All the other traffic stats for this host are correct except for Outgoing traffic on this one particular interface.
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • chocho63
    • Jun 2005
    • 53
    Pb reporting traffic
    I've got the same problem with beta5. It worked fine with type 'numeric' on beta2, but values are strange with 'numeric 64 bits' in beta5.
    • herr_bpl
      • Jan 2006
      • 15
      Yes, I can confirm it too, i even cleaned out database and no luck, still those gigabytes there...
      • herr_bpl
        • Jan 2006
        • 15
        I guess it is because counter on port is something over 2000000000 ...
        [root@hermes root]# snmpwalk -v 1 -c public 10.200.200.17 .1.3.6.1.2.1.2.2.1.16.3
        IF-MIB::ifOutOctets.3 = Counter32: 3220320828
        But value in database is something like 307445717877260288.000000
        Below is a sniff from debug
        005878:20060106:181430 SNMP [[email protected]:161:0]
        005878:20060106:181430 OID [.1.3.6.1.2.1.2.2.1.16.3]
        005878:20060106:181430 In get_value_SNMP() 0.2
        005878:20060106:181430 In get_value_SNMP() 0.3
        005878:20060106:181430 Status send [0]
        005878:20060106:181430 In get_value_SNMP() 0.4
        005878:20060106:181430 In get_value_SNMP() 1
        005878:20060106:181430 In get_value_SNMP() 2
        005878:20060106:181430 AV loop()
        005878:20060106:181430 OID [.1.3.6.1.2.1.2.2.1.16.3] Type [65] Value[18446744072684625374]
        005878:20060106:181430 In process_new_value()
        005878:20060106:181430 In add_history(ifOutOctets3,,3,1)
        005878:20060106:181430 In add_history(17914,UINT64:18446744072684625374)
        005878:20060106:181430 ITEM_STORE_SPEED_PER_SECOND(ifOutOctets3,999999999 999.999878,0.000000)
        Siim
        • razorgt
          • Sep 2005
          • 21
          I have the same problem, only on some routers for some reason. Any thoughts as to a fix anyone?
          Glenn
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            I did lots of testing today. ZABBIX results are perfectly in sync with results of snmpget/snmpwalk here (the latest Ubuntu, SNMP v1).
            I believe that the huge values are related to a bug (?) in net-snmp libraries.
            Are you on 32 or 64bit systems?
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
            • chocho63
              • Jun 2005
              • 53
              I'm on a 32 bits Intel System
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Please can you try the latest zabbix_server/poller/checks_snmp.c from CVS. Hopefully it fixes this problem.
                Note that this file will generate some extra debug files.
                Alexei Vladishev
                My Twitter
                • chocho63
                  • Jun 2005
                  • 53
                  That works correctly with this patch.
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    Excellent! Please could you post extract from log file which has different results for UI64 and ULONG? Thanks.
                    Alexei Vladishev
                    My Twitter
                    • chocho63
                      • Jun 2005
                      • 53
                      Here is a sample of my log file :
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] UI64[18446744072748322272]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] ULONG[3333737952]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] UI64[746277083]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] ULONG[746277083]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] UI64[18446744073122259149]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] ULONG[3707674829]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] UI64[18446744072054222590]
                      001513:20060112:161301 OID [IF-MIB::ifOutOctets.2] Type [65] ULONG[2639638270]
                      001513:20060112:161302 OID [IF-MIB::ifInOctets.2] Type [65] UI64[18446744072921099701]
                      001513:20060112:161302 OID [IF-MIB::ifInOctets.2] Type [65] ULONG[3506515381]
                      001513:20060112:161302 OID [IF-MIB::ifInOctets.2] Type [65] UI64[746845043]
                      001513:20060112:161302 OID [IF-MIB::ifInOctets.2] Type [65] ULONG[746845043]
                      • Alexei
                        Founder, CEO
                        • Sep 2004
                        • 5654
                        Thanks. Everything seems to be fine. You may use the very latest checks_snmp.c to get rid of the messages. Thanks again!
                        Alexei Vladishev
                        My Twitter
