Graph templates not working (beta5) - user error?
  • bbrendon
    • Sep 2005
    • 873
    So i have a template linked to hosts. When i add a graph to a template (config -> graphs), it says "[Graph added]", but it doesn't show the graph name and still says "No graphs defined", even if i refresh the screen.
    User error or bug?
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • bambin0
    • Apr 2006
    did you figure this out?
    I and rickarpd are having the same problem. I'm running beta8. It used to work for me in beta2, so I'd say bug.
    Here's the thread:
    • Holser
      • Apr 2006
      • 10
      The same issue.
      After update I ran into the same issue. It looks like frontend doesn't show the graphs correctly. I checked database and they were added but I don't see them in web interface so I can't add the settings to the graphs. Furthermore, the issue persists in beta9 so I think Alexei have to look at this issue and resolve it as soon as possible. GD works fine and I don't see anything weird in apache logs. So the issue is defenitely in scripts.
      P.S Alexei, if you need more details or want to check this issue on my server PM me or send a message to me.
      • rickardp
        • Dec 2004
        • 27
        1.1beta9 - Graphs with templates do work but not as expected
        The graphs can be found in the Configuration-->Graphs section, select Groups "all" and Hosts "all".
        In the templates section you expect to see the graphs created solely for this template (whether they are connected to items or not) but it doesn't work like this, only when you have connected items to a graph do they appear in the template section.
        The handling of graphs for the templates section should be reworked to behave as people expect it to.
