hi,
this is the debug output on a fresh installed gentoo linux with net-snmp used as described for receiving traps and pipes it to the snmptrap.sh shellscript to feed the trapperd:
---snip /tmp/zabbix_trapperd.log---
012174:20041208:194137 Got line:snmptraps:snmptraps:host.domain.tld 22 FastEthernet0/21 ethernetCsmacd IF-MIB::linkDown
---snap /tmp/zabbix_trapperd.log---
but in the database it will be saved as:
---snip---
---snap---
so the "::linkDown" part was cut off.
The "problem" ist this line in the zabbix_trapperd.c file:
value_string=(char *)strtok(NULL,":");
I was unable to tell if there was a good reason why you want to read only until the next ":" in the trapstring or if what you realy wanted was to fetch the entire rest of the string? Bug or feature?
Keep up the good work! I only played around with the system for a few hours but what I saw until now is a VERY NICE!
/T
---snip---
---snap---
/T
