Updated dokumentation for beta5 (items / macros)?
  • Wolfgang
    • Apr 2005
    • 116
    Is there a place where one can get an updated list of items and macros that are available in beta5?
    Example from the current 1.1 manual.
    vfs.file.time[file<, mode>]	File time information. Number of seconds.
    The mode is optional.
    If mode is missing 'modify' is used.
    Mode is referenced but not explained further.
    or this one
    vfs.file.regexp[file, user]	???	???	???
    vfs.file.regmatch[file, user]	???	???	???
    Also the capibilties of the win32 agent are having a "?" in the last table.
    I tried to get the supported items out of the sourcecode, but it is not trivial.
    Same for macros.
    I understand that this is work in progress and especially documentation takes its time.
    Anyway, any help is apreciated, becauses it makes testing a lot easier.
    Wolfgang
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
