agent and agentd
  • ghislain
    • Jun 2005
    • 160
    agent and agentd
    I have a little issue with the agent.
    When i use zabbix-agentd -p it report that
    vfs.fs.size[/,free]
    is supported and i got an answer.
    When i use zabbix-agent with inetd i cannot get ay of the value to work but one: system[uname]. All the other values that appear in the agentd are "not supported" on agent. I do not understand why ?
    This is not a communication problem as the agent report the uname so why should agent support less than agentd ? For technical reason (process limit) i cannot run agentd.
    I use precompiled agent from zabbix freeBSD4.11 on freeBSD system. The server is on a debian system running zabbix 1.1b5. I tried to compile the agent v1.1b5 but i get the same result: only uname is reported.
    regards,
    Ghislain.
    Regards,
    Ghislain.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I cannot replicate it on our test systems. Everything work perfect. Anyone else having the same issue?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • ghislain
      • Jun 2005
      • 160
      hello,
      i found the problem. It was not related to zabbix but a problem with inetd, i was running the agent with a user that has not enough privileges to gather the data..Doh !
      Regards,
      Regards,
      Ghislain.
