UserParameter & ZabbixW32 1.1 beta5
  • zvn
    • Jan 2006
    • 10
    Hi!
    I am using zabbix on linux and windows hosts.
    On windows host in c:\zabbix_agentd.conf created UserParameter=tcpest3389,cmd.exe /c netstat -n -p TCP | find /c ":3389"
    On zabbix server added item:
    Description #term sessions
    Host my.host
    Type Zabbix agent
    Key tcpest3389
    Units
    Use multiplier Do not use
    Update interval (in sec) 120
    Keep history (in days) 90
    Keep trends (in days) 365
    Status Monitored
    Type of information Numeric (float)
    Store value As is
    And I can not get values of this UserParameter.
    Other items for my.host is working.
    Where I'm wrong?
    Thank you, Valery.
  • KarmaPolice
    • Oct 2005
    • 95
    Originally posted by zvn
    Hi!
    Host my.host
    Type Zabbix agent
    Key tcpest3389
    Units
    Status Monitored
    Store value As is
    Where I'm wrong?
    Thank you, Valery.
    I could be mistaken, but i think that that command returns a newline at the end of the command therefore zabbix would be receiving data it didn't know how to interperet.... i'm not sure how you would do this in windows, but you need to do something similar to what 'head -1' would do for linux on the output of that command.....
    This is all a bit of a stab in the dark but everything else seems to check out ok.
    1 other question: is that your only custom UserParameter ??
    • zvn
      • Jan 2006
      • 10
      In windows return of command (I am output return to file) ended by 0x0D 0x0A, in linux 0x0A
      Zabbix 1.1 beta2 agent for windows (and server also) working without this troubles...
      I am use two UserParameters on windows hosts:
      UserParameter=tcpest3389,cmd.exe /c netstat -n -p TCP | find /c ":3389 "
      UserParameter=tcpest1521,cmd.exe /c netstat -n -p TCP | find /c ":1521 "
      On linux hosts any troubles with UserParameter absent.
      • zvn
        • Jan 2006
        • 10
        server log is:
        Parameter [tcpest3389] is not supported by agent on host [hr] Old status [0]
        What does it mean? On server I'm install agent from 1.1beta5.
        I'm change
        UserParameter=tcpest3389,echo 1
        and in log same string.
        And I can not get this data from my.host
        • zvn
          • Jan 2006
          • 10
          What does it mean? On _______windows server________ I'm install agent from 1.1beta5.
          • zvn
            • Jan 2006
            • 10
            I make some test:
            create file c:\zabbix\tst with folowing content (two chars): 0x031 and 0x0A
            and add UserParameter=tst,type c:\zabbix\tst
            In server log:
            Parameter [tst] is not supported by agent on host [my.host] Old status [0]
            But for old UserParameters I can see in server log:
            Type of received value [1
            ] is not sutable for [my.host]
