Configuration of discovery rules
  • 753713
    • Apr 2006
    • 137
    has anyone examples or howto of "CONFIGURATION OF DISCOVERY RULES" in the version 1.9?
    thanks
    753713
    ______________________________
    Version : 2.0.x
    Server OS: Ubuntu 12.04
    Zabbix Servers: 12
    Monitored Windows Server: ~ 1000
  • zalex_ua
    • Oct 2009
    • 1286
    Documentation (draft) about Low Level Discovery already exists, but it is not yet available for all to read. Ask a developers for documentation.
    I've tested LLD a lot.
    • zalex_ua
      • Oct 2009
      • 1286
      Originally posted by sbockelman
      I was looking to test the low level documentation. From the forums you have said that you have received a copy. Can you send it my way?
      So, thanks to your request, the developers have opened access to the 2.0 documentation.
      Read:
      http://www.zabbix.com/documentation/...ig/lldiscovery
      • 753713
        • Apr 2006
        • 137
        Thanks!!!
        I will test LLD in my network next week.
        Version : 2.0.x
        Zabbix Servers: 12
        • zalex_ua
          • Oct 2009
          • 1286
          Originally posted by 753713
          Thanks!!!
          The tracker has several ZBXNEXT created by me , which related to LLD.
          Take a look and if you agree then you can vote.
          • 753713
            • Apr 2006
            • 137
            HD Monitoring running without problems in my enviroment ,
            but how I can browse services in windows?
            many thanks,
            753713
            Version : 2.0.x
            Zabbix Servers: 12
            • zalex_ua
              • Oct 2009
              • 1286
              HD? cool! but this is typo
              I do not see any sense in this
              See services[<type>,<state>,<exclude>] key.
              • 753713
                • Apr 2006
                • 137
                with services[<type>,<state>,<exclude>] I have only a list with services.
                The idea is, I discover all (running/stoped/disabled) services on my win server, I create a rule and item prototype and I can see all services and services states (similar snmp interfaces discovery).
                Here my screenshot with manually configuration.
                Version : 2.0.x
                Zabbix Servers: 12
                • sbockelman
                  • Oct 2008
                  • 16
                  Using LLD Macros in trigger equations
                  Here is what I am trying to accomplish. Custom vfs.fs.discovery that will return the following on each server:
                  {#FSNAME} - name of the filesystem
                  {#FSTYPE} - type of filesystem
                  {#FSTRIGGER} - value in % that trigger will alert. This value will be pulled in from a file stored locally on a server or return a default. ie 90
                  So for each filesystem, I will be able to modify what % the trigger gets set off at.
                  This is what I want my trigger to look like:
                  {Template_OS_Linux:vfs.fs.size[{#FSNAME},pused].last(0)}>{#FSTRIGGER}
                  However, after saving I get:
                  ERROR: Cannot update trigger
                  * Array
                  Is this just a bug in zabbix 1.9.1?
