Problem with 1.1beta5 images.sql file
  • dakkonz
    • Oct 2005
    • 20
    Hey guys,
    When i try to dump the data for images.sql i have the following error
    ERROR 1048 (23000) at line 24: Column 'image' cannot be null
    The mysql command in images.sql is as follow
    insert into images values(1,1,"Hub",load_file("/home/zabbix/zabbix/create/data/images/Hub.png"));
    Can anyone tell me how to solve this?
    Thanks and Regards
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I think it is because of lack of read permissions on images files. MySQL user (usually 'mysql') is unable to read them. See ZABBIX Manual for more details.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dakkonz
      • Oct 2005
      • 20
      hmm i have already changed the permission to chmod 444 and
      I have shifted all the images file into /var/tmp/images/
      but when trying to insert the sql commands I still get the error saying that column image cannot be null.
      What is the load_file() function suppose to do? what is the data that is suppose to be stored in that column?
      Sorry i am quite new to zabbix and linux. So not too sure about many things
      thanks and regards
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Move all image files to /tmp and then modify images.sql to have this location in load_file().
        Alexei Vladishev
        My Twitter
        • dakkonz
          • Oct 2005
          • 20
          I have moved all the file into /var/tmp/images and have set chmod 777 for them all.
          However i am still getting the same error that the column image cannot be null.
          This is mysql command:
          insert into images values(1,1,"Hub",load_file("/var/tmp/images/Hub.png"));
          MySQL is version 5.0.15
          Thanks and Regards
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Are you sure the mysql user can access this directory? Have you tried this?
            Alexei Vladishev
            My Twitter
            • dakkonz
              • Oct 2005
              • 20
              Haha Solved it already. MySQL user does not have the FILE Privilege.
              Thanks for your help Alexei
