How to clean out database?
  • edeus
    • Aug 2005
    • 120
    I seem to have a lot of junk in my database, some hundreds of dead triggers and other misc entries. I know they shouldnt be there because I went so far as to delete every trigger accessible.
    Certain that there could be a problem caused here, I emptyed a few tables that were clearly just trash.
    Is there an official word on how to "refresh" or "reset" the zabbix db back to a "good" state?
    My concern is that since I have been upgrading for several versions, there is a lot of bad lines in there that could be causing some of the wierd bugs. Is there a way to bulk export then import back in?
    Thanks.
  • Nate Bell
    • Feb 2005
    • 141
    I don't have the methods, or syntax for you, but yes, you can replace parts of your database in bulk. I know you can copy data from one database to another, so you could create a fresh Zabbix database, and then systematically copy the stuff you want to keep, and leave the rest.
    Nate
