I'm running Zabbix 1.1beta5 server and agent on RedHat linux. When I add a new simple check on the server, I get the error:
Simple check [check_service[http,www.mywebsite.com]] is not supported
I'm setting up the following item:
Description: Website Availability
Host: www.mywebsite.com
Type: Simple Check
Key: http
Units:
Use Multiplier: Do not use
Update Interval: 30
Status: Monitored
Type of information: Numeric (float)
Store value: As is
When I add the item, I'm getting these errors in zabbix_server.log:
012522:20060120:120002 Simple check [check_service[http,www.mywebsite.com]] is not supported
012522:20060120:120002 Parameter [http] is not supported by agent on host [www.mywebsite.com] Old status [0]
012522:20060120:120010 Simple check [check_service[http,www.mywebsite.com]] is not supported
012522:20060120:120010 Parameter [http] is not supported by agent on host [www.mywebsite.com] Old status [0]
012753:20060120:120010 Parameter [http] became supported by agent on host [www.mywebsite.com]
Any ideas what I might be doing wrong?
Thanks!
John
Type: Simple Check
Key: http
Units:
Update Interval: 30
Status: Monitored
Store value: As is
Thanks!
John
