trigger rename and actions in Zabbix 1.9.1
  • bilik
    • Feb 2011
    Then i try to rename trigger, trigger name doesn't changes , I need to clone and type new name , and delete the old trigger.
    then i go to configure->actions and try to edit action , i get error
    reset() [<a href='function.reset'>function.reset</a>]: Passed variable is not an array or object[/var/www/html/actionconf.php:754]
    but update works.
    Another problem comes , when i copy item to a group , there is no way back to delete that items from group, i had to go and delete it from database.
  • zalex_ua
    • Oct 2009
    • 1286
    one question - you created a new DB with 1.9.1 DB shema?
    Or you use 1.9.1 frontend with the 1.8 DB shema?
    • bilik
      • Feb 2011
      yes , i had installed everything from zero with what was in alpha zabbix version
      • zalex_ua
        • Oct 2009
        • 1286
        you know what is alpha version?
        at least is a 1.9.2 version, which is much better then 1.9.1
        So, speaking about bugs in the 1.9.1 slightly is not relevant.
        The problems with the trigger renaming is solved already.
        About action editing - may be this
        p.s. i'm author of both issue request
        • bilik
          • Feb 2011
          where get newest version of zabbix ? because http://www.zabbix.com/download.php is 1.9.1 , and from that i thought it was the newest release
          • JBo
            • Jan 2011
            • 310
            You already have the correct link: http://www.zabbix.com/download.php
            Just read titles above download links:
            • Zabbix 1.8.4 (stable)
            • Zabbix 1.9.1 (Second Alpha Release of 2.0)
            Newest stable version is 1.8.4.
            Regards,
            JBo
            • zalex_ua
              • Oct 2009
              • 1286
              bah, I'm sorry, i misleading, 1.9.2 not released yet.
              I'm followed to latest trunk (pre-1.9.2) and so I'm confused.
              As JBo said - it better for you to use stable version.
              • fmrapid
                • Aug 2010
                • 43
                Though some would argue that 1.8.4 is a bit broken for SNMP polling. 1.8.4 has great features, but what are features when the basic stuff does not work well. pre1.8.5 has the fix in, I would suggest that one if you are a big SNMP user or 1.8.3 if you can wait for 1.8.5.
                Cheers,
                • richlv
                  • Oct 2005
                  • 3112
                  hmm. might be helpful to note specific issue
