Configuration:
Detected OS: hpux11.31
Install path: /usr/local
Compilation arch: hpux
Compiler: gcc
Compiler flags: -g -O2 -I/opt/iexpress/mysql/include/mysql -fomit-frame-pointer -fpic -DHPUX11 -DSNPRINTF_RETURN_TRUNC -DHAVE_BROKEN_PREAD -DHAVE_BROKEN_GETPASS -DNO_FCNTL_NONBLOCK -DDO_NOT_REMOVE_THREAD_WRAPPERS -DHAVE_BROKEN_PTHREAD_COND_TIMEDWAIT -DUNIV_HPUX -DUNIV_HPUX -I/opt/openssl/include -I. -I/opt/iexpress/net-snmp/include
Enable server: yes
Server details:
With database: MySQL
WEB Monitoring via: cURL
Native Jabber: no
SNMP: net-snmp
IPMI: no
SSH: no
Linker flags: -L/opt/iexpress/mysql/lib/mysql -L/opt/openssl/lib/ -L/opt/iexpress/curl/lib -lcurl -lxnet -L/opt/openssl/lib -L/opt/iexpress/net-snmp/lib -lnetsnmp -lelf -lnm -lipv6 -lcrypto -L/opt/openssl/lib -L/opt/iexpress/net-snmp/lib -lnetsnmp -lelf -lnm -lipv6 -lcrypto
Libraries: -lm -liconv -lmysqlclient -lcurl -lnetsnmp
Enable proxy: no
Enable agent: no
Enable Java proxy: no
LDAP support: no
IPv6 support: yes
* Now run 'make install' *
* Thank you for using Zabbix! *
* <http://www.zabbix.com> *
./configure --enable-server --with-mysql --enable-ipv6 --with-libcurl --with-net-snmp
/usr/include/arpa/nameser_compat.h:134:1: warning: this is the location of the previous definition
net.c: In function 'NET_IF_DISCOVERY':
net.c:34: warning: assignment makes pointer from integer without a cast
net.c:34: error: invalid use of undefined type 'struct if_nameindex'
net.c:34: error: dereferencing pointer to incomplete type
net.c:37: error: invalid use of undefined type 'struct if_nameindex'
net.c:37: error: dereferencing pointer to incomplete type
*** Error exit code 1
Stop.
Stop.
Stop.
Stop.
Stop.
Server is rp4440 PARISC running HP-UX 11.31.
Compiler: gcc
Enable server: yes
Server details:
Native Jabber: no
SNMP: net-snmp
IPMI: no
SSH: no
Enable proxy: no
Enable agent: no
LDAP support: no
IPv6 support: yes
Stop.
Stop.
Stop.
Stop.
Stop.
